Lathe pen press - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Casual Conversation
  Forgot Password
Casual Conversation Off-topic, general chat.
Welcome to penturners.org!
Reply
Old 12-19-2018, 08:30 PM   #1 (permalink)
sbwertz's Avatar
Photos: 41
Default Lathe pen press
Has anyone used the lathe pen press from Craft Supplies? I have three blind turners just getting started with lathes at home, and it looks like it would be a great fit for them. It gives much better control than a lever operated pen press.
https://www.woodturnerscatalog.com/p...rm=pen%20press
__________________
Sharon in Phoenix
sbwertz is offline   Reply With Quote Top
Old 12-19-2018, 08:50 PM   #2 (permalink)
WriteON's Avatar
Photos: 0
Default
I would go for it. I use the PSI 2 piece set up. Same principle. Easier & substantially cheaper.
__________________
Current set up:
a pair of Jet 1015VS
Jet 1221VS
MidAmericaPool professional pool cue repair lathe
WriteON is offline   Reply With Quote Top
Old 12-19-2018, 08:56 PM   #3 (permalink)
sbwertz's Avatar
Photos: 41
Default
Thanks, Frank. The PSI one looks like it would do just as well for half the price.
__________________
Sharon in Phoenix
Advertisement
Old 12-19-2018, 09:15 PM   #4 (permalink)
WriteON's Avatar
Photos: 0
Default
There are small magnets in the center. Youíll want to glue them in place. They tend to come loose and attach to the head and tail stock. Youíll understand when you see it. Iím sorry I did not buy these before getting the lever presses. Simple. Cheap. Effective.
__________________
Current set up:
Jet 1221VS
Old 12-19-2018, 11:34 PM   #5 (permalink)
magpens's Avatar
Photos: 75
Default
If you are careful, you can do the pressing on a lathe without buying anything.
All you need is a couple of 1/2" Alumilite "dowel stubs" and a tailstock chuck that will take the 1/2" size. . You could even get by with 3/8". . I use such dowel stubs. . Just make sure that the ends are squared to the axis. . I use Alumilite because it is less likely to chip under pressure, but you can use PR if you are careful. . You could even use hardwood or brass. . I don't see the need for anything but squared flat ends ... but I am not blind, so that may be a factor for those less fortunate than me ! . The key is to keep the pressure points at the center of the stubs.
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is online now   Reply With Quote Top
Old 12-20-2018, 12:49 AM   #6 (permalink)
TattooedTurner's Avatar
Photos: 278
Default
I have the one from CSUSA and love it. The nice thing about the pin that goes in one of the pieces is the diameter is the size of a pen mandrel. This allows you to slide a bushing over it which gives more support when pressing the parts in as well as automatically centering the barrel. Simple but clever, and might be enough of an advantage for your blind turners to justify the higher cost.
__________________
Jay
TattooedTurner is offline   Reply With Quote Top
Old 12-20-2018, 10:28 PM   #7 (permalink)
sbwertz's Avatar
Photos: 41
Default
Quote:
Thanks, that is a good point.
__________________
Sharon in Phoenix
Old 12-21-2018, 11:17 PM   #8 (permalink)
TonyL's Avatar
Photos: 6
Default
They are my favorite ones to use. I have about 4 different pen presses. I feel that I have the most control over the assembly with these.
Try the CSUSA ones; I will send you the funds via PP. My treat. Then you can compare them. If you accept my offer, send me the amount with tax and shipping of cost and I will send you the funds for a set.
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Old 12-22-2018, 07:06 AM   #9 (permalink)
Photos: 0
Default
I love this community. Just sayin'.
earl
greenacres2 is offline   Reply With Quote Top
Old 12-22-2018, 09:19 AM   #10 (permalink)
Photos: 0
Default
I have used the CSUSA set now for sometime. Bought them when they were $14 a set. They work great and I have put together several hundred pens with the same set. Agree they are much more controllable than the regular pen presses.
Tony, thanks for stepping up on this one.
Turncrazy43
turncrazy43 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
