I found a drill bit and...
Herb G
Southern Maryland
I have no idea why I have it. There are no markings on it at all.
It is a brad drill bit for wood. It measures 21/64" on my drill gauges.
It is not out of a set. Would this be used in pen making?
If so, which kits would it fit?
I sincerely have no idea why I even have it, let alone know what it's used for. It's bugging me to no end.
Any help out there?
Thanks in advance.
D.Oliver
Faith SD
You may be using it for a substitute for the "O" drill bit. I do that. The Flat Top kit is the one that pops to mind that calls for the "O" drill bit.
KenV
Juneau, Alaska.
Herb, that is a fat 5/16 bit. It would be one of several choices to drill for 3/8 by 16 bottle stopper threads.
While I have it in my drill index, can not remember using it for a pen.
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
The only kits that I'm aware of that specifically call for a 21/64 bit are the Seam Ripper and Euro Letter Opener by Hut Products. Other suppliers of those same kits call for a letter O or an 8mm or a 5/16 bit. While a 21/64 can be used in place of any of those 3 bits, it is about 0.3mm or 1/64" larger - which sometimes can be helpful.
Personally, I wouldn't use it for bottle stoppers though. My personal preference is to use a 9/32 bit. I like to drill the holes a little undersize, then tap them to 3/8-16 before threading onto a mandrel. That's just me though - others have different techniques.
Dale Allen
Massillon, OH
So you found the drill bit....
.......and Mitch found your drill!:biggrin:
Now get back to work!:laugh:
duncsuss
Wilmington, MA
Possibly part of a "loose tenon" joinery kit? If you have 5/16" dowels that are going to be glued in, a slightly oversized hole allows for good glue coverage (too tight a fit means no space for glue, and the joint is weaker).
sbwertz
Phoenix, AZ
Perhaps at some time you bought a "starter kit" that included bit and bushings and several pen kits.
