Sage advice
There are some Secrets that must be kept! It's part of the code.
psst .... over here ....
http://woodenpenworks.wordpress.com/2007/03/31/where-is-the-real-money-in-wooden-pen-making/
but the
REAL secret to ending up with a
Small fortune in penturning IS ......
Start out with a
LARGE fortune!!!!!! :biggrin:
I've never heard more truth summed up in a couple of sentences regarding this subject. So true.
Well my advice is as follows....
Make fewer pens
Take longer to make each one - I now spend at least a week to get a pen made.
I putch around and decide which style pen I will make
Then I sift through my never emptying box(es) of various blanks. to decide which blank I will bless.
I then carefully decide what part of the blank I will use and cut a correct length piece.
I let that set for a day so to and look at it several times be sure. If it doesn't please me, I cut another piece.
Then I get out my drill bit(s) chuck and baracuda and put them on the drill. I check about 9 times to make sure I have the correct bit, that way I drill the wrong size hole only about 5% of the time. I drill the hole and put the tools away (assuming this is not one of the 5%).
I don't predrill, this is a hobby.
I let the blank sit and stew for a while wondering what its fate will be.
I now get out the tube and go through the messy process of getting it glued into the blank.
Now I get out the centers or the mandrel and set the lathe up - by now 3 or 4 days have gone by and I am anticipating how nice the pen will be when it is finished.
Turning takes very little time sanding and finishing takes quite a bit but I usually spread that over several days. Turn one day, sand to final demensions another finish another. I've taken to letting the finished barrel(s) hang around for awhile before assembling the pen...and may do the finish over.
Assembly once started is usually a 5 minute job.
A week has passed, I have enjoyed time in my shop. I have not gotten frustrated because I mixed parts, or put the barrel on the wrong pen or any of a dozen othe hazards. If I ruin a barrel, I just salvage the tube and start over. I don't use $100 blanks.
I don't spend a small fortune on supplies blanks and kits
