DRAFT Rules 2019 IAP BASH Pretty Wood Pen Contest
Brian G
Bloomington, MN
*subject to minor edits or changes*
Who am I kidding?. . . these are the same as last BASH, so they are unlikely to need editing or changing.
In addition to the Universal Contest Rules, the following rules apply:
Blank Material
-Your blank material must be wood. No plastics, no composites, no metal, no casting, no mixed wood and plastics, nor any material other than wood is allowed.
-No embellishments to the blank are allowed. This means, for example, no inlay, onlay, overlay, stickers, oops bands, CNC, laser art, segmenting, lamination, celtic knots, burning, engraving, or carving is allowed and will cause disqualification.
-Stabilized wood is allowed.
-Dyes, stains, pigmentation, paints, or any other colorants are not allowed.
Pen kit/component hardware
-Any commercially available kit/component hardware may be used, whether ballpoint, fountain, or rollerball.
-No modification to the kit/component hardware is allowed. You must use all parts of the stock kit/component set.
-Kitless pens are not allowed.
Photographs
-Two photographs are required for entry. One photograph must be clip up, nib to the left. The second photograph must be clip up, nib to the right. This gives a view of both sides of the pen. If you do not abide by this constraint, you will be asked to resubmit photographs or risk disqualification.
-Please submit photographs of maximum 800 x 600. You should hit this mark, and you are responsible for cropping and sizing your photographs. If you don't meet this requirement, you will be asked to resubmit photographs or risk disqualification.
-You may use a commercially available, clear plastic pen stand as a prop.
-No other props are allowed.
-Use a single-colored, plain background. The color and intensity of the background affects the highlights of your pen. The background should let your pen stand out, not interfere with it.
-No montages, watermarks, borders or any other identifying marks that might reveal the identity of the maker.
-Here's a set of two photographs that would qualify. They have the clip on the upside of the photo, and nibs to the left and right. They also fit the 800 pixel width limit, though they are short of the 600 pixel height limit. As long as the image "fits" in an 800 x 600 pixel box, it qualifies.
-Clip up, Nib to the left:
attachment.php
-Clip up, nib to the right:
attachment.php
-If I had used a clear plastic pen stand as the prop, I would have oriented the pen so that the final photo showed the pen on a diagonal.
To Enter
Submit your entry by email to: (wait for email address to be provided) and include the following with your entry:
-Name, Username, email address,
-the pretty wood you chose to use (please, no stories)
-the two pictures required.
Do not post your entry in this thread
One entry per person
Please send a private message to Brian G after you submit your entry to help ensure that your entry has been received.
Entries for The Pretty Wood Contest will be accepted between (dates to be determined).
Prizes to be announced
Prizes
First -
Second -
Third -
Perhaps some other unexpected prizes TBD
Might be a good reason to use a pretty wood blank from your Christmas haul, or from that gnarly looking chunk from the firewood pile.
I'm sure this will be a very well attended contest.
But Please remember, that a Pen Stand and/or Pen Box will make your Pretty Wooden Pen look even more prettier.
So Please make sure you enter the Pen Stand and Pen Box contest too
