Definitions
Old Griz
Passed Away Oct 4, 2013
Hagerstown, MD, USA.
Found this on another site... a must read for the new woodworkers.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted airplane part you were drying.
BELT SANDER: Used for making rectangular gouges in wood.
PAD SANDER: Used for easing the edges of the rectangular gouges.
RANDOM ORBIT SANDER: Used for removing the marks left by the PAD SANDER, usually on any surface perpendicular to the original gouge. May also be used to make semicircular gouges in wood.
DETAIL SANDER: Makes triangular gouges, generally in blind corners.
BISCUIT JOINER: Tool used to misalign wood in a very consistent manner which can then be sanded heavily (See BELT SANDER).
CHISEL: Multi use tool - good for making deep cuts in the hand.
CORDLESS DRILL/POWER SCREWDRIVER: Used for rounding out Phillips screw heads at high speed.
ROUTER: Used to darken wood by friction and make smoke. For this latter purpose, it replaces the incense used by primitive woodworking cultures who wished to influence the woodworking deities. When used with a ROUTER TABLE this tool can be used to make varying profiles using a single bit and a single depth setting.
TAPE MEASURE: This device is used to measure length. It should be immediately dropped onto concrete several times so that measurements made with it will then agree with every other TAPE MEASURE in the world.
NAILSET: Used to make small, round depressions around the head of a finish nail. Principally used for decoration.
CLAMPS: These come in two sizes: too small and loaned to an in-law.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age; with the proper accessories, used to destroy perfectly good wood in many ways.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
SABER SAW: See Hacksaw.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
XYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper.
8-FOOT LONG 2X4: Used for levering an automobile upward off a hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbors to see if he has another hydraulic floor jack.
PHONE (alt.): Tool for calling your brother-in-law to see if he has your CLAMPS .
TABLE SAW: Used to make wood slightly narrower than necessary.
MITER SAW: Used to make wood slightly shorter than necessary.
THICKNESS PLANER: Used to make wood slightly thinner than necessary.
JOINTER: Used to make the too thin, too short, too narrow wood perfectly straight. Very useful for making two sides of a board perfectly straight but non-parallel.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog**** off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last over tightened 58 years ago by someone at ERCO, and neatly rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a $0.50 part.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit.
HAMMER (alt.): Originally employed as a weapon of war, the hammer continues
to be the tool of choice for making medium sized circular depressions
in wooden surfaces of all kinds.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts.
UTILITY KNIFE (alt.): Used to slice through the fingers. For purposes of sanitation, the blades are easily replaceable.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also the next tool that you will need.
EXPLETIVE: A balm, usually applied verbally in hindsight, which somehow eases those pains and indignities following our every deficiency in foresight.
angboy
North Las Vegas, NV
"CORDLESS DRILL/POWER SCREWDRIVER: Used for rounding out Phillips screw heads at high speed."
"DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted airplane part you were drying."
As people have probably figured out, I'm not the most tool savvy person- still in the learning stage! And probably about 90% of the things mentioned here I wouldn't know what they were if they bit me. BUT, I'm beginning to feel better about my skills and knowledge, considering that Tom has provided me with some reassurance that I was correctly using my cordless drill last night when I tried to attach my faceplate to the back of a bowl blank. Tom, now if you could just tell me what tool I need to be able to get that screw back out! [:D][:D]
I also must have been doing OK when I tackled using a drill press for the very first time last night- when I turned it on for the first time, I was practically standing behind it, with my arm stretched out as far as possible so I was as far away from IT as possible! If I'd had a long stick, I would have stood across the room and pushed the button. And that was before even putting anything on it to drill- this was just to see the drill bit turn! But I wanted to be sure I stood as far back as possible so that I was really seeing just how good my DP was, by being sure it could fling something really far. If I'd stood too close, that would have made it too easy!
alamocdc
San Antonio, Texas, USA.
LATHE: A machine used to spin an irregularly shaped piece of wood and promptly launch it through the closed shop window at the slightest touch of any turning tool.
JimGo
North Wales, PA
Originally posted by angboy
<br />Tom, now if you could just tell me what tool I need to be able to get that screw back out! [:D][:D]
I'm not Tom, but...try a pair of vice-grip pliers, if you have them. If not, a dremel tool or hack saw can be used to cut a groove in the top of the screw so you can use a standard screwdriver. If you don't have any of those, since you're going to have to purchase a tool anyway, they make special screwdriver-like tools for just such emergencies.
I did the same thing when I first turned on my lathe - you should have seen how scared I was of my little block of pine wood! I wasn't QUITE that bad with the drill press, but close!
dubdrvrkev
Gilbert, AZ, USA.
Originally posted by Daniel
<br />It's nice to know my tools are functioning properly
LOL Mine too.
The turning sheet would be fun.
Drill Press- Used to make oblong holes at an angle through intended pen blank.
Table Saw- In history it was used to make boards too narrow, however in modern times it serves well as a shelf and workbench.
Center Finder- Used to make lines on the end of blanks to show where Not to put the drive center.
Skew Chisel- See Dammit Tool
Jointer- Hey that was college, drop it already.
Planer- I flew to Hawaii just last year.
1/2x16" craftsmen screw driver- Fresh from the grinder it is your new hollowing tool.
Scrap wood bin- Potenial project bin
Thumbs
Muncy, PA, USA.
Tom, I'm still trying to figure out if this is a collection of one liners or a selection of valid and useful observations to educate young workers to the realities of the work place environment. Painfully apt observations I might add........
LMAO, too![}:)]
Brent
Illinois, USA.
How about the snap ring pliers, you know the pliers with the little prongs to compress a snap ring just long enough for you to move your hand toward your project and then you watch it fly across the room but never see where it lands,
jwoodwright
Anchorage, Alaska, USA.
Tom, those where great and true, here's a couple...
Hammer- Tool for striking nails, finger nails as well...
Sewing Needle, tool for releaving Blood Blister, from using Channel Lock Pliers that pinched when they slipped...
Sewing Needle Heated to red hot, good for releaving pressure of trapped blood under finger nail, see hammer...
