Can you figure it out?
DozerMite
Banned
I'm trying to find out how many grams are in a teaspoon. I haven't found a definitive answer yet.
Maybe some of our members from the other side of the pond have a better answer than I have been able to find?
DozerMite
Banned
A gram is a measurement of weight, while a teaspoon is a measurement of volume or capacity.
That part I know, but the conversion charts differ in the answer. Some say 4 some 4.2 and others 5.
There are receptacles that are sized in grams. So there has to be a conversion to volume.:confused:
soligen
Sterling Heights, Michigan
Yup, it depends on what you are measuring. Every substance will have a different conversion ratio. For what you are measuring, you can determine it experimentaly if you have an accurate scale.
cwolfs69
portsmouth, va
one gram of water is the weight of one cc/ml of water. 4.9 cc/ml is 1 teaspoon (us). so as long as you are talking water this conversion will work. any other substance you will have to know the specific gravity (water has a specific gravity of 1.00) of the substance to convert. otherwise the conversion from a weight/mass (grams) measurement to a volume (teaspoon) measurement cannot be done.
PTownSubbie
Chesapeake, VA
I agree with Dennis....each substance has a different density and therefore has a different weight when a certain volume is used.....
I also base that on what I see when I get my mica powders....Each one is 1 ounce of powder but each container has a different amount of powder based on how dense it is.....
Each one will be different.
Drstrangefart
Woodstock, Ga. U.S.A.
Simple - sand weighs more than flour so a teaspoon of sand will weight more than a teaspoon of flour.
So, if this is true, which is heavier_ 1000 lbs of bricks or 1000 lbs of feathers?:wink::cool:
Sorry, just couldn't resist!
They weigh the same, but a cubic yard of each one would be drastically different. (Sorry for the anti-joke there.)
PenMan1
Eatonton, Georgia
Here's a good rule of thumb. 1 teaspoon is equal to 4 grams of table sugar. The conversion is a little different for each substance, but the 4:1 calculation will get you "in the ball park" with most everyday substances other than feathers, gold, lead, etc.
StephenM
Webster Groves, MO
If you really want to confuse someone, ask them which weighs more - 1 pound of lead or 1 pound of gold.
(The answer is a pound of lead)
The answer and explanation are hidden somewhere on this page.
Gold is measured in troy ounces (1 troy ounce = 1.09 reg. ounce) but there are 12 troy ounces in a pound and 16 regular ounces in a pound. So a regular pound weighs more than a troy pound.
