Casual Conversation Off-topic, general chat. |
Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
What is a good product for cleaning brass by just dipping in a solution??? Not looking for a caustic acid. Something safe and does it need a neutralizer after dipped and what is it. I can not wipe with any kind of polish. Thanks in advance.
I was thinking something like jewelry cleaner.
__________________
John T. ![]() ![]() |
#2 (permalink) |
Dip it in Brasso polish? I think there's a liquid version that would do it, but I'm pretty sure you still want to wipe or polish it, perhaps with a small buffing attachment on a dremel type tool?
Also, a fairly simple alcohol cleaning solution in an ultrasonic cleaner should work too, but it won't shine it up very much.
__________________
Click Here to go to Pen Turner's Anonymous Meeting Attendance is not mandatory, unless you're addicted to turning pens. |
#3 (permalink) | |
Tarn-X ?
__________________
Your secrets are safe with me. There's a good chance I wasn't listening anyway. My lathes: Floor Lathe Bench top lathe |
Advertisement |
#5 (permalink) |
Easy Magic "No Mix" Solution Options:
Cover with ketchup for 20 to 30 minutes or Soak in coke for 2 to 3 hours or experiment with other acidic solutions (lemon juice, bar keepers friend, CLR). A good rinse with clean water (and then hand drying (don't use heat to dry)) should be adequate after "cleaning" with any of the above. If the magic solutions don't do it for you and the parts are small, consider investing in a cheap tumbler from HF and some crushed walnut shell. Let the machine do the work for you. Ed |
#7 (permalink) |
Photos:
Look up lemi shine. It's for dishwashers, reloaders use it to clean brass cartridge cases. I use a lot of it and rinse with dish soap and waterfront clean water. Gun powder is a chemical so you can't be adding other chemicals to the mix so to speak. I tumble my brass but many do not, they just use lemi shine. It's $3-4 a jar at the Walmart here.
Just google lemi shine brass clean up, polish, or whatever you want. It will take you to lots of discussions on it. ![]() Sent from my iPad using Penturners.org mobile app |
#8 (permalink) |
When in the navy, and in a pinch, we use Tabasco sauce to shine brass... 'course it does require rubbing it on, rubbing the brass a bit and then wiping it off... you wanted a dip and now wipe, so guess Tabasco is actually out.
__________________
Chuck Tellico Plains, TN https://www.etsy.com/shop/TellicoTurnings If you look for trouble, it will find you! |
#9 (permalink) |
What's the reason you are unable to use polish?
The most effective method, is to use a jewelers or greaseless rouge with either a puff or string wheel, using no pressure on the wheel. Just lightly touch the ends of the strings and rotate toward the wheel. Using that motion, is less abrasive. The other products made for dipping, don't give the bright appearance of the brass, but seems a little dull looking to me. I hope you find a method that works for you.
__________________
-John- |
Bookmarks |
Thread Tools | |
Display Modes | |
