Bowl vs Spindle Gouges - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Casual Conversation
  Forgot Password
Casual Conversation Off-topic, general chat.
Welcome to penturners.org!
Reply
Old 02-16-2009, 12:57 PM   #1 (permalink)
OldWrangler's Avatar
Photos: 0
Default Bowl vs Spindle Gouges
Maybe I am a little dense or just don't read enough but I am having trouble seeing the difference between a bowl gouge and a spindle gouge and why they can't be used interchangeably.
The bowl gouge looks to have deeper flutes but how does that help. I have been doing my bowls inside with a round nose scraper and seems to work. What say you bowl turning pundits?
__________________
What this country really needs are more unemployed politicians!!!
OldWrangler is offline   Reply With Quote Top
Old 02-16-2009, 01:02 PM   #2 (permalink)
JimB's Avatar
Photos: 11
Default
I'm not really 100% sure on this but I believe the flute of the spindle gouge is more open and is more likely to get a catch.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Old 02-16-2009, 01:33 PM   #3 (permalink)
marcruby's Avatar
Photos: 19
Default
Actually if you are talking about true spindle gouges - often refered to as detail gouges, there are some small differences - spindle gouges are a bit shallower to make beads and coves easier. But you can often use a bowl gouge as a spindle gouge.
Now if you are talking about Spindle roughing gouges there are a number of differences. An SRG is may by rolling out sheet steel - very deep with high corners. If gives you a lot of area to rough out spindles - if sharp it can come close to a final cut in the right hands.
That form makes it very difficult to use safely inside a bowl. The high corners like to wander into the wood and the bevel is a bit too radical. If you get a catch (and you will) the tool will get slammed onto the rest with a lot of twisting force. This puts enough pressure on the tang entering the handle that it will eventually break. Now comes the horror movie - when the tool breaks it has a knack for flipping up in the air, dropping back onto the work and getting fired at whatever rpm the lathe is running at right at your most vulneralble parts (anything that isn't covered with kevlar).
The other downside is that SRGs don't give you the full range of cuts you can get from a bowl gauge.
Usually at this point some doofus shows up and announces that if you know what you are doing you can use an SRG on a bowl. Sure, but maybe one in a 100 turners can concentrate on avoiding all the things that can go wrong for longer than it takes to wonder where the stupid cat went.
Marc
__________________
I'm late, I'm late...
marcruby is offline   Reply With Quote Top
Advertisement
Old 02-16-2009, 02:17 PM   #4 (permalink)
cbatzi01's Avatar
Photos: 10
Default
In my experience true bowl gouges are a lot bigger (diameter/length). The steel is more rounded allowing you to roll it over easier on the rest. It may sounds crazy, but I believe there is less flex with a bowl gouge as you have more and more tool hanging over the rest and into the whirling blank. My first bowl was turned with a spindle gouge and was a terrifying experience. I know use both round nose bowl gouge, and a fingernail grind bowl gouge, with a scraper just for finishing cuts. Feels much safer, and the shavings are nice and spiral-like. Try it and you might like it!
__________________
"I've made a huge mistake..."
cbatzi01 is offline   Reply With Quote Top
Old 02-16-2009, 02:51 PM   #5 (permalink)
Assistant Moderator
Vendor Liaison
maxwell_smart007's Avatar
Photos: 0
Default
The issue is that the spindle gouge is not meant for end-grain hollowing, as it may catch...when the happens, the spindle gouge is more likely to break, resulting in more danger than if one were using the proper tool...
__________________
"When it is dark enough, you can see the stars"
"He who can no longer pause to wonder and stand rapt in awe, is as good as dead; his eyes are closed."
maxwell_smart007 is offline   Reply With Quote Top
Old 02-16-2009, 03:20 PM   #6 (permalink)
Photos: 1
Default
That form makes it very difficult to use safely inside a bowl. The high corners like to wander into the wood and the bevel is a bit too radical. If you get a catch (and you will) the tool will get slammed onto the rest with a lot of twisting force. This puts enough pressure on the tang entering the wood that it will eventually break. Now comes the horror movie - when the tool breaks it has a knack for flipping up in the air, dropping back onto the work and getting fired at whatever rpm the lathe is running at right at your most vulneralble parts (anything that isn't covered with kevlar).
Marc
Or it will break your tool rest... which is another fun activity, ducking and covering when pieces of cast metal begin to fly in various directions in and around the shop.. DAMHIKT... primary reason why I have followed JimB's line of thought and gone to doing bowls with a bowl gouge. I do not and have not ever used a roughing gouge on the inside of a bowl, my catch was with a scraper in a Zebrawood bowl and I still haven't found all of the parts of the tool rest. I have used them to round the outside surface. And I find a spindle gouge/detail gouge to be a little too agressive for my taste on the inside of a bowl.
__________________
Chuck
Tellico Plains, TN
https://www.etsy.com/shop/TellicoTurnings
If you look for trouble, it will find you!
TellicoTurning is offline   Reply With Quote Top
Old 02-16-2009, 03:37 PM   #7 (permalink)
JimB's Avatar
Photos: 11
Default
Quote:
I don't know where I saw it but there is a chart somewhere that tells you how far you can extend a bowl gouge over the tool rest based on the diameter of the gouge. I believe I saw it in a catalog like CSUSA or one of the others. I can't seem to find it now.
__________________
Jim
West Henrietta, NY
Old 02-16-2009, 03:47 PM   #8 (permalink)
Art Fuldodger's Avatar
Photos: 0
Default
Spindle gouges are often shallower, and have a more acute angle on the bevel - so that you can roll them over and get into tight places to make beads and such.
Bowl gouges have deeper flutes, and usually a steeper angle on the bevel so that you can rub the bevel inside of a bowl without having to decline the tool so much.
Art Fuldodger is offline   Reply With Quote Top
Old 02-17-2009, 05:01 AM   #9 (permalink)
talbot's Avatar
Photos: 0
Default
Click on e-book for beginners: http://www.turningtools.co.uk/index.html
Its quite an informative site and good for reference.
regards, Bill
talbot is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
