Bookmarks - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Casual Conversation
  Forgot Password
Casual Conversation Off-topic, general chat.
Welcome to penturners.org!
Reply
Old 10-11-2018, 10:49 PM   #1 (permalink)
gtriever's Avatar
Photos: 3
Default Bookmarks
While searching the Woodturningz site this evening I came across some little gold-plated bookmark kits. Looks like an interesting way to use some of those blank cutoffs that find their way into a big box in the shop. Do these sell, or do they just take up space in your inventory?
gtriever is offline   Reply With Quote Top
Old 10-11-2018, 11:09 PM   #2 (permalink)
Photos: 34
Default
They sell , and they don`t take up much space . Not as easy to make as they might look , though .
1080Wayne is offline   Reply With Quote Top
Old 10-12-2018, 07:15 AM   #3 (permalink)
gtriever's Avatar
Photos: 3
Default
"Not as easy to make"? I figured this would take a tiny little chisel - now where to find one
Advertisement
Old 10-12-2018, 07:32 PM   #4 (permalink)
Photos: 34
Default
You are making a small thin disk , 18mm (0.7 in) diameter is what Berea`s website suggests (I prefer 20 mm , although that requires a larger chamfer on the underside to allow it to seat ) , with a thickness of 30-50 thou at the center , tapering to 5-10 at the edge . That usually requires stabilized or CA hardened wood especially if cross grain , or plastic . It also doesn`t allow much room for error when using typical pen blank cutoffs .
There are 3 ways that I know of to make them . The first is to use a 3 or 4 jaw chuck to hold a square or round or irregular full size blank , turn to the desired diameter , shape the end as you wish , sand the end , part off the disc , and repeat . Some parts will end up in your scrap bin . Overall conversion efficiency depends on your skill , size of parting tool , tool sharpness , and luck .
The second way is to take your small pieces , cut them about 0.1 inch thick with a thin kerf saw , sand one side a bit , attach it to a face plate with 2 sided tape , and carefully turn it down to size . The tape does not hold well if it gets too hot , and thin wood does not have a lot of heat holding capacity . Both turning and sanding can generate quite a bit of heat .
The third way is to take a small piece as above , attach it with 2 sided tape to a dop stick of the desired finished diameter , shape the piece on a face grinder (watch the heat) , then finish sand by hand with the piece still on the stick .
Wouldn`t bother with the tiny little chisel . Regular tools , but SHARP .
Old 10-13-2018, 06:48 AM   #5 (permalink)
gtriever's Avatar
Photos: 3
Default
Thanks for the tips - now a silly question : do you have better results with CA or Epoxy for gluing these to the hardware?
Old 10-14-2018, 01:26 AM   #6 (permalink)
Photos: 34
Default
Quote:
Don`t really like CA for that unless it is very thick (like molasses) , but then have to use accelerator and if any squeezes out it can be hard to remove . Don`t like 5 minute epoxy any more because the manufacturers know they will sell more of it when they only sell it in a dual tube squeeze package , which is guaranteed to leak in any drawer you store it in , causing you to throw out something you didn`t want to . Plus , it has some colour , and squeeze out isn`t easily removable .
Therefore , My last resort is clear Dow Corning RTV sealant , but I`m sure any clear silicone would work . It bonds well to wood . I do rough the gluing surface of the bookmark with a diamond burr to get some mechanical bond . Any squeeze out is fairly easily removed with a sharp pointed knife . Just make sure the disc is still centered a few minutes after setting it in place , because it can walk a bit due to the elastic nature of the silicone .
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
