Abranet Rolls
SteveG
Eugene, Oregon 97404
Sue, when you take the plunge and buy by the roll, the unit cost is WAY down. With having the rolls comes freedom...freedom to use the abrasive as intended, then discard it and pull out another, fresh strip. By not continuing to use that spent strip of Abranet (to get the most out of it), you will enjoy your pen turning (yes, even the sanding part!) much more.
I strongly recommend all to consider buying by the roll, and as a result, be smiling more :):biggrin::):biggrin::):biggrin: as you go about your pen turning activities!
The other benefit is that your overall finish may improve too. :wink:
