tubular segmenting advice sought
mikebpeters
Greenwood, NS
Hi, I'm trying a bit of a variation on some of the cool work I have seen. Things aren't nearly as tight as they would need to be to make this a sale pen so it will be an experimental one only.
As you can see I have inserted pieces of aluminum tube into the lower barrel of a Jr Gent.
[/URL]
[/URL
How do you think I should/could finish these up?
I see a number of potential options.
Do nothing - leave them open to the brass tube below - clean them up of course, but that is all.
Fill with pieces of complimentary wooden dowelling
Fill with pieces of identical verawood
Fill with colored epoxy
walshjp17
Weddington, NC
Interesting concept. Some thoughts:
  • Tagua Nuts
  • CA on the bottom with colored stone chips
  • Clear epoxy with initials or a small design at the bottom
Janster
Nevada
What the heck! IF you are not selling it, I would go the a craft store and buy "Doll Eyes" in the appropriate size and use those!..? It would definitley be a first!... Be well................Jan
NittanyLion
State College PA
Nice job. I always get that "look" from the guy at the key machine when asking for the shavings......it helps to carry one of your pens when you explain it.
Dale Parrott
Goshen, Indiana
Mike,
I get brass shavings from lowes at the key cutting machine. They always give it to me for free. It can be held in place with CA. I've done a few crosses this way. Should look good on your blank.
Just thought I would add to this my experience. While picking up some supplies today at my local Lowe's I heard the key machine grinding away.:biggrin:
I waited for the line to go away and then talked to the associate about getting some of the filings or "dust " as he called it. Bottom line is after 2 phone calls to management and he kindly let me know the "dust" was toxic and it must be discarded in the trash. :confused:
I'm thinking my local hardware store maybe a better option at least where I live.
Dale
