Segmenting with M3 Blanks
LL Woodworks
North Texas
Has anyone done any segmenting with M3 blanks? More specifically, any segmenting with M3 / Aluminum / Wood? Is 2-part epoxy or CA better for segmenting M3? I usually use Locktite 2-part epoxy for wood and aluminum projects.
Thanks for any feed back as the M3 blanks are to expensive to experiment with.
Jim Burr
Banned
Reno, Nv
Haven't seen that one yet Lynn. I only use CA to fill segmented blanks as I turn them. Assembly is done with 2-part epoxy.
I think you can't go wrong using an epoxy. I have never used that material so I can not say for sure but do know I would have tried epoxy for sure only because that is what I use most of the times.
hewunch
Albany, GA
This was done with Thick CA
