Piano Key Ivory
allisnut
Shelby NC
I have a box full of keys from an old - at least 1950s but maybe a good bit older - piano. The ivory is in thin pieces glued to the pine keys. Most pieces pop right off.
Is there an easy way to be sure they are real ivory? I can see rings and patterns in some of the pieces, but I can't get a decent close up of a good sample.
I'm thinking this will be good segmenting material if I can get my patience and kerf tuned up just right. Any ideas for utilizing this material are welcomed!
PTsideshow
Macomb County Michigan
More than likely they are ivory, easiest test is the heated pin test on the back side. If it smells like burning plastic when a red hot pin is placed against it it isn't ivory. You only need the point end to do the test.
The piano key ivory is a favorite material for jewelry work. Don't neglect the black keys as a lot of them were made from ebony or other dark to black woods.
:clown:
Seem like a waste to just stand it on edge to get an accent piece. If you could incorporate them so they lay flat, now that would be worth seeing. Just an opinion.:)
