Copper color to segmented pen
Daddy1
Toledo, Ohio, USA.
I just started doing some pens with aluminum and I really like how it comes out. I would love to do the same with different colors, like a copper color. Any idea if there is different colors of flashing out there or a different way to get in more color other than the silver that come with the aluminum?
H2O
You can get small sheets of brass and copper at hobby stores.
They no longer carry it. At least not at the stores within a hundred miles of me. I've checked when I've been in them.
Use online metals, I think it is.
Skeleton2014
Lynnwood, WA. USA
Hobby Lobby sells copper sheets either online or in the stores. I bought the 4" x 10" x 0.025" thick copper sheet for $7.99 (used their 40% off coupon). They also have a thicker copper sheet (12" x 18" x 0.16" thick) for $22.99. I believe I found both in the aisle where they have model kits, model train supplies, rockets, etc. Good luck, Jeff
Skeleton2014
Lynnwood, WA. USA
I just remembered Home Depot had copper tape in 1.38" x 15 foot rolls (Corey's Slug and Snail Copper Tape Barrier) in the garden department. I used it last year during the steampunk PITH. I suppose it could be used for segmenting although, might be a little too thin.
Jeff
Rick_G
Bothwell, Ontario, Canada.
Considering your location you should have a metal mart or some similar type of store in the area. they will sell virtually all types of metal including copper and brass sheets by the square foot.
Daddy1
Toledo, Ohio, USA.
So here's another question. I sandwich the flashing in between pieces of the pen blank and then turn so the edge is what is seen. The flashing or sheets are copper/brass on the front and back but will the edges show the brass color?
D.Oliver
Faith SD
Years ago, I got small sheets from the craft store (Hobby Lobby) and they will show the copper color on the edges.
Daddy1
Toledo, Ohio, USA.
A finished product
Here is my first copper laced pen. Boy that copper is HARD! But I think it came out good!
wob50
Independence.
Real nice , cause I have a soft side for copper ,what size (thickness ) was the sheets
I will have to try this soon.
t001xa22
Arlington, TX
Kevin, another idea I would offer: use copper tubing in standard wall thicknesses. Cut off a small section, and mash it flat in a vise. What you end up with are two squares that can be separated when you cut them into discs to fit up with your material. I usually use 3/4" tubing. When this size is flattened, it will give you two pieces almost 1" across x whatever length cut you made from the tubing. I drill my pen tube size into the copper pieces while it is still stable enough to hold in a vise. It is a nice bonus to actually get two pieces from one section of copper tubing.
jfoh
If you use copper anneal it to make it softer and easier to work. Goes from hard as nails to almost soft as butter.
