Weird Wood
Cwalker935
Richmond, Va
A friend gave me these weird chunks of wood that he found while hunting. They appear to me to be where a limb had grown from a trunk and the wood surrounding the limb had rotted away. The remaining surface wood is surprising hard. I suspect the middle of these pieces may not be as hard. They are about 6" inches long. I think they may be cedar.
Has anyone tried to do anything with something similar? I think they may have promise as blanks, stabilized blanks or fusion castings. Any thoughts?
KenV
Juneau, Alaska.
Have seen those in connifers. locally they are spruce and hemlock. the lower limbs become very resin rich and do not rot. The ones I have cut are cracked/fractured resin and do not want to stay togerher. Have not tried Cactus Juice.
Cut along a sid and see what you can get.
They do burn hot and help start fires.
Cwalker935
Richmond, Va
I cut one up last night and it is definitely connifer and very pitchy. I will try to turn some of the pieces and do a worthless wood casting with some of the other pieces.
Marko50
Orem, UT
That's exactly what they are. Pine knots.
