Vacuum Pump
stonepecker
central Minnesota
Today is the last day of a 25% off at Harbor freight.
They have a great pump.........in fact there are two. At two different prices.
Either would work for stabilizing.
I don't know what you are doing with a vacuum pump........you didn't tell us.
But these would/could be great starter pumps for a beginning.
gimpy
Danville, Pa
Going to be using it for stabilization of wood......sorry, I forgot that part
Schroedc
Rushford MN
I've been using the 4CFM JB pump with no issues (Except the time I had a whoopsie and sucked resin into it and had to tear apart and clean) Unless you're running a huge chamber 3-4 CFM is plenty for stabilization, I started out with an old pump that was only 1.5 CFM and it just took longer.
gimpy
Danville, Pa
Thank you all for your input, my new vacuum pump was delivered today. I purchased a JB Eliminator DV-6E......can't wait to use it.......Need to get the plumbing kit from Curtis as well as the gauge.......probably order that tomorrow
