Turning a 3d Printed Barrel
Lucky2
New Brunswick/ Canada
John, are these ever a neat idea, they would be great for people who would like to choose their own colors for a blank. And for other reasons as well, hopefully they will be good sellers for you. I do have one issue though, and it is about how strong these blanks would be. Wouldn't they break apart if dropped on a cement or other hard floor? What would stop the small pieces from breaking away, seeing as how everything is being divided by plastic? What or how are the small pieces held in place, would the heat generated from the epoxy setting up be enough to melt them together?
Len
moke
Cedar Rapids, Iowa
That is an awesome blank....very nice.
You need to get rid of that glove though.....you need to read some horror stories of Woodworkers that wear gloves. A turner in my club says, "the only thing gloves do is keep track of the severed finger after the accident they cause"
just my .02....
Rangertrek
Bossier City, Louisiana, USA
Len, thanks for the comments. I have actually dropped one on my shop floor and it don not break or separate. Only one test so far. They would be like other segments and acrylics, some will break if dropped. The small pieces are actually 'walls' in the mold. All the walls are attached at intersections. Heat from the epoxy does not melt the plastic. I am going to be using another plastic that has heat properties that will stand up to Alumilite type resin.
I asked this in another thread you started so it is a redundant ??? but will all resins adhere to this plastic?? I know not all glues work well with all plastics. Have you tested with the resins being used today?? I know silmar has a tendency to shrink a bit. Does the plastic need to be treated in any way such as sanded to give tooth or a chemical used to give it a tooth?? Thanks. :)
RangeRat
Arkansas
Just watched the vid and really love the blue color and design of the blank mold. I'll check out the blanks on your site when I have time later.
mark james
IAP Collection, Curator
Medina, Ohio
Great Video John, and I liked the music - not at all a distraction to me. But your calming voice almost lulled me to sleep :) - just kidding.
As a wood segmenter, I really like what these molds offer those who don't want to "play with little sticks." The design and color opportunities are wonderful - keep up the good work and good luck. Variety and choices are good.
A very minor thought - mostly for those not familiar with segmented blanks that are best placed equi-distance from the middle of the pattern (i.e., the end caps/segments are the same thickness. Consider sanding the ends to fit the tube before gluing in the blank to insure equal dimensions. No critique for what you did for this video - To me you nailed the dimensions; not an easy skill for newbies who will try these molds.
Well done.
Don Rabchenuk
Middleburg, FL
John T. I have tested with Liquid Diamonds, Black Palm, and Amazing Clear Cast. That is all I have tried to date.
OK those are all epoxy resins. They stick to just about anything. :):)
John, I have been watching these on Facebook and most of the people talking about them have been using either epoxy or polyurethane (Alumilite) with these molds. I do not recall anyone using poly resins in them.
Rangertrek
The poly resins heat up while curing and can cause molds made from PLA to warp. I will soon be using another resin, PETG, which can take the heat from those resins.
Thanks, for the comments.
Rangertrek
Thanks for the kind comments. I actually had a head cold and sinus issues during the video. So. voice was a bit scratchy. :biggrin:
Well done.
