Thanks Chris (Wishman)!!
EBorraga
Passed Away July 17, 2022
Louisville, KY
Received some watch faces from Chris Yesterday!! Now it's time to get busy :biggrin: Thanks again my friend!!
Ernie if I may make a few suggestions because you are stepping up with better quality dials. I had seen a couple your other ones. You need to press those dials entirely around the tubes because the the very ends can be a problem when turning. Also get some good quality hands for those dials I hate when people do not put hands on a watch dial. At least that is just me. Anyway look forward to seeing what you come up with. Good luck.
EBorraga
Louisville, KY
Appreciate the feedback, and thee resin magnifies the gap on a painted tube. Hence the reason most use carbon fiber. And I always put hands on my blanks. It's a PITB, but worth it to me. Now to find matching hands that don't break the bank.
thewishman
Reynoldsburg, Ohio, USA.
I just turned a bunch of blanks from Ernie - the blanks I have are very nicely made. The square side of the blanks distort the look of the dials. They are wrapped correctly, and tightly,around the tubes.
I used to want hands on everything, but random hands on high-end dials make them look cheap.
Ernie, the green Maurice Lacroix dial is one of my favorites. I hope it brings you both happiness and $$$.
