Spiral Clear Casting with a Blank Drying Motor
Bob in SF
San Francisco
I'm enjoying my clear PVC pipe casting, but wanted to add controlled color spiraling throughout the blank - so I got a PennState blank drying system; clamped the (nice and slow 3rpm) motor to my bench with shaft facing upright upwards; drilled/tapped/turned a PVC pipe mold holder on the lathe, and screwed it onto the shaft; then lathe-bored the bottom of a wood square to serve as a platform for bangle mold rotation; poured a couple of color mixes into the slowly rotating mold; and to my surprise and pleasure, the simple system works, and the motor turns bi-directionally - stop it for a moment, and it turns the opposite direction for more possibilities; too much fun not to share; pix:
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
- Bob
Charlie_W
Sterling, VA USA
If you sit a cat on the revolving platform, it can keep a 360 degree watch on your shop for mice and not have to turn it's head!!!:biggrin:
Bob in SF
San Francisco
Great idea, Charlie - wonder if kitty will be compatible with the dog on the neighboring platform...opens up a menagerie of possibilities:wink:
magpens
Canada
Cool, Bob !!!! . Looks like you put your name on everything you own, even your "rubber" gloves !!!
Bob in SF
San Francisco
Today's refinements - single (10cc + aquarium tubing) syringe and/or double
(25ml Empty Double-Barrel Cartridge/Syringe with Plunger (1:1 mix ratio) - AmLee Epoxy Supply) syringe in hopes of spiraling into tighter control:
attachment.php
attachment.php
Douglas - rotisserie (or any other slow-geared) motor should work fine - and it just takes a few minutes to turn a wood fitting to mate your PVC tube/stopper to the motor shaft.
(sorry about name-on-everything - old habits die hard:wink:)
Warm regards, Bob
