Selecting Wood to Stabilize
NJ Mike
New Jersey
All - Any tips on what type/condition of wood to look for to stabilize? I tried Cactus Juice on some rotten cherry (well dried), but I think the cracks/nooks were too large for the juice to fill.
Much thanks.
Gary Beasley
Marietta, Ga. USA
Much thanks.
I've done rotten cherry too, sometimes it takes a second or third trip through the process to get it solid. Try crosscuts in the spalted stuff.
Usually the wood I've treated is still firm but has lost weight from the decay, not much but noticeable. Anything soft enough to damage easily is a good target for Cactus juice.
robutacion
Australia - SA Adelaide Hills
The cactus juice won't "Fill" in the voids all it does is make the wood fibers stronger , it binds them with an polymer to strengthen the wood . If you want to fill voids you need to use a casting resin of some type .
Yes, I totally agree with that...!
I believe that allowing the wood to soak in the CJ for a least 6 hours after the pump has been turned off, is one of the most efficient ways to "saturate" the wood/blank and to prevent the CJ excess from draining away from the wood, wrapping each blank in foil paper without tears, it will keep most of the CJ in the blanks and therefore have a better chance to fill some of the smaller cracks.
Best of luck,
Cheers
George
NJ Mike
New Jersey
Thank you all! I think the voids were too big for the CJ. I'll use all the tips - thanks so much. Hmmm......casting.....maybe I'll convert my paint tank to a pressure pot......
SawdustHappy
Indiana
It all depends what you are looking for. I have had success with drift wood & CJ. Followed by then putting it through some casting resin. The results are crazy awesome!
