Casting Rookie needs help with pressure pot set up - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making
  Forgot Password
Welcome to penturners.org!
Reply
Old 05-23-2018, 01:51 AM   #11 (permalink)
Photos: 34
Default
The noise might possibly be from the hold down clamps either stretching slightly (not good ) or from them rotating the pot lid ever so slightly . The first should be obvious if the clamps are looser after removing pressure than when you tightened them . The second problem is exacerbated by incorrect clamping procedure . Do not tighten them going clockwise around the pot , one after another . That will pretty much guarantee the lid will rotate in the same direction when pressurized . I find it better to 1 and 3 together by hand , then 2 and 4 , followed by large vice grip individually on 1 , 3 , 2 and 4 , not excessively tight , just a bit more than is easy to apply by hand .
1080Wayne is offline   Reply With Quote Top
Old 08-04-2018, 01:56 PM   #12 (permalink)
Marko50's Avatar
Photos: 2
Default
Popping sound in a pressure pot?? RUN FOR YOUR LIFE!!!
Marko50 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
