Question about Stabilizer - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making
  Forgot Password
Welcome to penturners.org!
Reply
Old 09-11-2017, 08:45 AM   #1 (permalink)
BeeAMaker's Avatar
Photos: 0
Default Question about Stabilizer
So far I have only used Cactus Juice for stabilizing. I have noticed after backing it draws some of the resin out of the wood forming hard clumps of resin on the outside of the blanks.
I have some spalted wood blanks I need to stabilize that has holes and groves in them. I don't want these holes and groves filling in with Stabilizer. Any tricks to Keep the CJ from filling in these voids while baking?
__________________
When you speak, you repeat what you already know. When you listen you learn...
Get the Pressure Pot Caddy!
Vertical Casting System
The MakerHive
BeeAMaker is offline   Reply With Quote Top
Old 09-14-2017, 07:51 AM   #2 (permalink)
twehr's Avatar
Photos: 0
Default
Chances are your temperature is too high. That is what normally causes the bleed out. If you are using a toaster over, don't expect its thermostat to be accurate nor for it regulate within a small range.
I added a digital temp controller with dual controls and set it up to turn on heat when it needs it and to turn on a computer fan I mounted in the back when it is too warm. Even with that, the temp swing is about +/- 8 degrees. But that is WAY better than the toaster over can do on its own. On its own, you may see swings of +/- 30 degrees.
At the very least, you should get a good oven thermometer and calibrate your toaster oven's thermostat to it.
twehr is offline   Reply With Quote Top
Old 09-14-2017, 08:04 AM   #3 (permalink)
adirondak5's Avatar
Photos: 0
Default
I use a drip pan under the rack in my toaster oven and I do not wrap the blanks in tin foil , any bleed out while baking goes in the drip pan and doesn't pool on blanks , any blanks with big voids or holes I try to place hole void side down .
__________________
Herb
Long Island , NY
adirondak5 is offline   Reply With Quote Top
Advertisement
Old 09-14-2017, 08:13 AM   #4 (permalink)
BeeAMaker's Avatar
Photos: 0
Default
Quote:
I have, it stays fairly consistent at 200f.
I may try the drip method,
Thanks for the replys!
__________________
The MakerHive
Old 09-14-2017, 10:06 AM   #5 (permalink)
Photos: 0
Default
Quote:
I do exactly the same thing. It works well.
PatrickR is online now   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
