Plastic blank with no smell
Dale Allen
Massillon, OH
I was given 5 blanks and turned one of them round to see what the pattern would look like. There is no smell to the plastic at all. I though he said they were alumilite but as I recall alumilite has an odor when turned. Or am I mistaken on that?
Anyway, I wanted to get the opinions of you folks about how the blank looks.
It has some interesting swirl patterns and a lot of different colors.
MikeinSC
SC
Alumilite does not have a strong odor or virtually no odor. Acrylic acetate has an odor when turned, PR has an odor when being made. Ebonite also has an odor when turned.
Surprise, Arizona
All the resin blanks I've turned have a smell, some much worse than others. Alumilite isn't bad at all, polyresin has the strongest odor but not nearly as bad as when casting with it.
Imaginethat
Maricopa, AZ
Dale, Alumilite turns real easy and is a pleasure to turn, so that may be a way to tell if it is alumilite. But as I recall alumilite does not have a strong odor.
Woodchipper
Cleveland, TN
I do have a "sort of" answer. When I turn plastics with any odor, I hook up the Shop Vac to draw off the odor. Do the same when applying CA.
Dale Allen
Massillon, OH
Here is another blank, same blank from 2 sides.
This one is trying to tell me to order one of those steampunk kits.:biggrin:
(Had to lay it on a rubber band to keep it from rolling around)
Rolandranch
Tucson, AZ
Those are really nice! Would definitely make a nice steampunk.
