Painting and aluminum foil - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making
  Forgot Password
Welcome to penturners.org!
Reply
Old 02-03-2016, 12:22 PM   #1 (permalink)
Photos: 2
Default Painting and aluminum foil
I would like to make some blanks with aluminum foil wrapped around the tube (possibly slightly crinkled or with a design), paint the foil, seal the foil?, glue "something" to the foil, and cast it in PR. My questions are primarily what glue(s) to use, what kind of paint, and what to seal the paint before I cast it.
My previous experience is turning wood blanks (including segmented with fwood veneer or aluminum), acrylic blanks, and scrolling some patterns in the blank to fill with inlace or PR. Foil is a new area and I appreciate any help I can get. Thanks!
jimmyz is offline   Reply With Quote Top
Old 02-03-2016, 12:55 PM   #2 (permalink)
mark james's Avatar
Photos: 481
Default
Hi Jim. I'd suggest you consider using the foils that are self-stick:
Foil Tape
View in gallery
Have fun!
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Old 02-03-2016, 02:45 PM   #3 (permalink)
Photos: 262
Default
good afternoon Jim. As suggested by mark i use the self adhesive foil and the ones I have painted I used rattle-can paint. I did not use any sort of sealant.
hope this helps and good casting.
__________________
Perry Bridges
Buchanan,Georgia
www.perryspens.com
Some folk have something to say,others have to say something.
papaturner is offline   Reply With Quote Top
Advertisement
Old 02-03-2016, 05:28 PM   #4 (permalink)
Photos: 2
Default
Went to the web for information on the self stick aluminum tape, and it says something about printing on the tape. Is this correct, or does it just look like aluminum foil with glue on the back?
Old 02-03-2016, 06:44 PM   #5 (permalink)
thewishman's Avatar
Photos: 0
Default
This is what I use:
Robot Check
__________________
Chris
Non Impedite Raditioni Cogitationis.
(Unencumbered by the thought process.)
Tom and Ray Magliozzi
thewishman is offline   Reply With Quote Top
Old 02-03-2016, 07:03 PM   #6 (permalink)
Photos: 262
Default
Quote:
I use the common alum.. tape that the heat & air folks use.
__________________
Perry Bridges
Buchanan,Georgia
www.perryspens.com
Old 02-11-2016, 02:02 PM   #7 (permalink)
79spitfire's Avatar
Photos: 0
Default
I found the Aluminum at Home Depot, the copper can be had from some of the stained glass suppliers, it's used for Tiffany style stained glass projects.
79spitfire is offline   Reply With Quote Top
Old 02-12-2016, 07:19 AM   #8 (permalink)
Photos: 0
Default
Not to hijack, but what is the tool you use to create the uniformed holes or dots on the tape? Where do you get them? Thanks for sharing. Jim
Jimmykoko2 is offline   Reply With Quote Top
Old 02-12-2016, 08:09 AM   #9 (permalink)
Photos: 0
Default
jimmyz, you seem to be a creative person, so don't stop now, keep the gears turning. Make each one of your blanks different! Think like: lots of pine bark around that can be crushed by hand, glue the foil on the tube, let dry, add another layer of glue, sprinkle on crushed bark, not necessary to completely fill the surface, then finish and turn the blank to see what you have created!
__________________
Barry L Elder
nativewooder is offline   Reply With Quote Top
Old 02-21-2016, 03:26 PM   #10 (permalink)
Photos: 0
Default
Quote:
I learned a trick fish carvers use to make scale impressions in wood. Use the handle of a socket wrench to roll out the impression. I haven't done it with foil but do not see why it wouldn't work if you laid it flat on the wood.
EdGallop41 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
aluminum foil , casting , painting
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
