Image help!!! Perfect to Crap when barrel trimming - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making
  Forgot Password
Welcome to penturners.org!
Reply
Old 09-12-2016, 09:16 PM   #1 (permalink)
Photos: 0
Default Image help!!! Perfect to Crap when barrel trimming
So I casted 2 images today and they came out perfect!!! Then I barreled trimed them and it looked as if air bubbles showed up. Possibly the tube breaking lose a bit from the alumilite??? I attached a pic after turning.
My process
CA GLUE IMAGE ON TUBE
4 coats of CA thin to seal image
Waited 7 hrs
Poured Alumilite (5 min open time) / placed in pressure pot 60psi for 4 hrs
Pulled out looked amazing
Barreled trim and what looked to be airbubbles next to tube
Turned got worse
Help!!!!!!!
Jeepmiller09 is offline   Reply With Quote Top
Old 09-12-2016, 09:32 PM   #2 (permalink)
stuckinohio's Avatar
Photos: 3
Default
I think you should ditch the barrel trimmer and use a jig on the lathe to sand the blank down to length and flatness. Most here use ones made by a forum member rherrell. His products are first rate and very good priced.
__________________
Lewis
stuckinohio is offline   Reply With Quote Top
Old 09-12-2016, 09:35 PM   #3 (permalink)
Photos: 3
Default
Another problem could be, and maybe more likely is you put too much pressure on the tailstock, causing the alumilite to separate from the blank. You have to be very light with these types of blanks.
__________________
Lewis
Advertisement
Old 09-12-2016, 11:04 PM   #4 (permalink)
Photos: 0
Default
Sanding the barrels (on a lathe) is the only way to go in my opinion.
There are several different ways to do this. Find the one that works for you.
__________________
It's not "Having what you want"......it is "Wanting what you have".
"Don't go riding on that long black train."
stonepecker is offline   Reply With Quote Top
Old 09-13-2016, 02:35 AM   #5 (permalink)
Photos: 8
Default
A barrel trimmer wont normally cause tiny air bubbles to appear next to the tube, it can cause de-lamination (a ghost effect at the end of the blank)
I think you didn't wait long enough for the CA to de-gas, now if you had said 7 DAYS then that sounds more like it... but 7 hours is just too soon to then cast.
__________________
MY WEBSITE
George Watkins is offline   Reply With Quote Top
Old 09-13-2016, 09:30 AM   #6 (permalink)
Member Liaison
leehljp's Avatar
Photos: 46
Default
In addition to what has been mentioned above is a technique issue. You can rough turn them when you want, but it is better to trim the ends BEFORE you rough turn them, IMO. And you did turn them too soon after casting. You can get away with turning that quick but your percentages of failures increases significantly.
Bladed Barrel trimmers are iffy. If the blank is hard enough, if the trimmer is sharp enough, if you don't have any chatter, if you don't apply a tad too much pressure. . .
I like to CA over some ebony and other oily woods. From experience, I do not use a trimmer, but rather a sander. I KNOW what is going to happen 50% of the time with a barrel trimmer, and I have 3 carbide trimmers, sharpened by professionals.
Success is accompanied by patience. Part of the success is to enjoy the journey, not rush to the end.
__________________
Hank Lee
Experience is what you get when you don't get what you wanted!
leehljp is offline   Reply With Quote Top
Old 09-13-2016, 10:14 AM   #7 (permalink)
Photos: 0
Default
I noitced you waited 7 hours after coating with ca glue before casting. I wait 3 days. This is a debated topic but I've never heard anyone casting that soon after applying c.a.
Kenny Durrant is offline   Reply With Quote Top
Old 09-13-2016, 07:02 PM   #8 (permalink)
m4skinner's Avatar
Photos: 1
Default
Quote:
I use pr and I cast after ca well under 7hrs with no problem everday.
m4skinner is offline   Reply With Quote Top
Old 09-13-2016, 07:06 PM   #9 (permalink)
m4skinner's Avatar
Photos: 1
Default
Quote:
My process
Waited 7 hrs
Turned got worse
Help!!!!!!!
How long after printing your images did you wait to seal with ca ?
Old 09-13-2016, 11:41 PM   #10 (permalink)
Photos: 0
Default
Quote:
My process
Waited 7 hrs
Turned got worse
Help!!!!!!!
I waited about a week after printing them... Just because my work schedule became crazy
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
