Help with casting
dnjmyers
Is there anything you can use to cast blanks and stabilize blanks. I would really love to use one product if I can.
eharri446
Marietta, GA
To the best of my knowledge there is not one manufacturer who makes both casting material and stabilization material. I may be wrong but that seems to be what is shown in the various posts.
JohnU
Ottawa, Illinois
Unfortunately not. When you cast, its pressure you use to compress air by pumping it in to a pressure tank with an air compressor. When you stabilize you pull air out with a vacuum pump to force the resin in while bringing back to equal pressure. Also, Casting resins don't penetrate like stabilizing resins because of the way they are cured.
