Casting casting molds
Aces-High
Boulder, Colorado
Question.
If I am making casting molds, what are the inner dimensions that would be most usable? I see that ptown makes theirs 5 1/4 squared by 7/8? Not sure on the thickness. I have some material that I am making them and then will offer to people here.
Thanks,
Jason
Most pen blanks are 3/4 inch square by 5 inch long. You can make a single mold or you can make a block and cut into blanks. Some use pvc pipe or other tubes to make round blanks. Did that answer you question ?
Dave
Hey, Jason. I asked about this and did some research on basic blank sizes, cast or not. With a lot of input and some experimenting, I have determined 5 1/4 square by 3/4 or more is the best size.
At 5" there are a lot of kits that leave you with a short leftover piece that isn't usable for much. At 5 1/4 there are still a lot of kits that you can get two blanks out of. Just my perception at this point.
The type of resin that will be cast matters. PR shrinks, so the mold cavity needs to be larger than 3/4. If I make a mold for myself, I want at least enough size so I can trim them square and have a better idea how the blank looks inside.
I am leaning toward 5 1/2 square with enough depth for 7/8".
w =(b*n) + (k*(n-1)) + 2k
where:
w = width of block mold cavity
b = final blank width
n = number of blanks in the block
k = kerf width of blade used to cut blanks
Plug and chug to see what width might minimize the waste.
I use a 1/16" kerf circular saw blade in the table saw to cut blanks. I like that better than a thinner bandsaw blade, because it leaves a cleaner cut.
The "2k" is for cleaning the edges of the two outsides of the block. You could figure 1/16" for each outside edge regardless of the kerf for cutting the blanks.
My math says that, for 3/4" square blanks, a 5" internal cavity would yield 6 blanks. For 13/16" blanks, a 5-5/16" internal cavity would yield 6 blanks. For 7/8" blanks, a 4-7/8" internal cavity would yield 5, 7/8" blanks and 1, 5/8" blank.
As I mentioned, PR "shrinks" as it cures. Also consider that a slight meniscus forms when the casting is under pressure. I would make the depth 1" and not 7/8" because then the pour isn't right to the brim and the risk of spillage declines.
I think most people can "eyeball" a 1/8" margin at the top. After a few tries, filling the block mold to the right depth is a matter of correct measuring.
I'd suggest considering, if you have the tooling to do it, routing a finger groove in the ends of the block mold to make picking it up and moving it easier. That's what I'll do in the next set of block molds I make.
Length. . . I think 5-1/4" is long enough, and I'd discourage 5-1/2" unless the plan is to square them after demolding. Blanks of 5-1/4" fit nicely in a SFRB for shipping.
All intended to be helpful. Good luck.
Math error. You'd need an internal dimension of 5-11/16" for 6, 7/8" blanks. You'd need 5-7/16" to get the 5, 7/8" and one 5/8" blank.
