Casting Alumilite???
This question came up on another forum and being I do not use Alumilite I thought I would ask here. When you people mix this do you use containers with the recycle code #5 as does Silmar???
Justturnin
Houston, Tx
I still use the #5 but I am not sure it is necessary. I just buy the same cups because they are cheap and more durable during vigorous stirring.
JD Combs Sr
Owingsville, KY
The only cup you SHOULD NOT use for Alumilite is paper cups and DAMHIKT. I will soak right through the paper leaving a ring on your bench if it sets for more than a few minutes.
