Welcome to penturners.org!You've found the home of The International Association of Penturners. You are currently viewing our site as a guest, which gives you limited access to view discussions, photos, and library articles.Consider joining our community today. You'll have full access to all of our content, be able to enter our contests, find local chapters near you, and post your questions and share your experience with our members all over the world. Membership is completely free!! If you have any problems with the registration process or your account login, please contact us. |
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Photos:
I have the app and lists but I am wondering if there is a published cross-reference of which kits use the same bushings (if that makes sense). In other words, now that I have amassed over 20 bushing sets I am wondering if there is a list of pen kits that all take the same size bushing. If I have a Sierra set, what other pens can I make with that set?
#2 (permalink) | |
Photos:
Good question. I am wondering the same thing myself. I just discovered, for example, that the Euro/Summit bushings also work with the Summit Letter Opener. What else is out there?
Quote:
__________________
#3 (permalink) |
Photos:
I'm still learning as well. You mentioned the Sierra. I use the same bushings for the Sierra, Gatsby and Wallstreet 2. I use the same bushings for the Triton, Jr.Gent 2 and the Kojent. I've noticed that a lot of the cigar kits will use the same bushings. The way I found these out was that I would buy bushings for the kit I was buying and then check to see if they were the same when I had them in hand at home. Now keep in mind that just because the bushings are the same the tube length may not be. The Kojent and Jr.Gent 2 have the same tubes and although the Triton uses the same diameter tubes and the cap is the same length but the pen tube is shorter. The Wallstreet 2 click and twist are the same except the click has a longer tube. So as stated before always check all measurements before swapping tools and parts.
Advertisement |
#4 (permalink) |
I’ve wondered this myself. BTW says what pen kits a set of bushings works with, so I just write that on the baggie. Seeing as how I have a set of Triton bushings right next to me, I know they also work with the Atrax. I know a lot of the Jr kits use the same bushings as well. A compiled list would definitely be nice, although I’ve pretty much narrowed myself down to a handful or so of kits that I stick to for the most part.
__________________
Jay |
#5 (permalink) |
I have been making pens for nearly 10 years and I know of no such list for bushings.
I have quite a sizeable collection of bushings and found it challenging to keep them organized and accessible. Fairly recently I moved away from using bushings. . I measure the pen components with a digital caliper and then frequently check the size of my turning with the caliper. . When I am close to final size (but still oversize) I stop turning and sand down to the required size, taking into account the finish that I will be applying. . For a CA finish, I sand about 0.002" below the required size.
__________________
Mal Kids rule the world !!! .... eventually if not already ! |
#6 (permalink) |
If you have the app there is a way but it isn’t perfect. If you enter all the bushing diameters that are listed for a pen in the search function it will return a list of all the pens with those numbers listed. When entering the numbers in the search separate them by a space not a comma. It isn’t a perfect system but it does work.
__________________
Jim West Henrietta, NY |
#7 (permalink) | |
I do not know of a list like that either. As to keeping them organized and accessible I keep mine in the clear plastic fishing tackle boxes with the removable dividers. I write on top of the lid with a permanent marker what kit it fits, it is divided in 2x2 in squares, works great i just hope i never drop that box !!
#8 (permalink) | |
Nope, no list known here either. For storage I use the little storage cases from Harbor Freight, p/n 90243 - 24 small boxes inside a larger box. Each individual box is labeled with the bushings number and which kit, and the cases are labeled by the main Pen Supplier - PSI, Berea, or Misc / Project Bushings.
#10 (permalink) |
I use a Dremel engraver to write the measurements and sometimes the kit that they are compatible with on the bushings. I keep the in very small plastic bags and hung from a shelf. Having said that, I still have a dozen or so strays, but at least they have the measurements and kit names on them. FWIW. I know this doesn't help with the cross referencing request. Sorry.
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln Peace, Tony Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA |
Bookmarks |
Tags |
bushings , tubes |
Thread Tools | |
Display Modes | |
