Best tube adhesive? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making
  Forgot Password
Welcome to penturners.org!
Reply
Old 05-10-2018, 02:18 PM   #1 (permalink)
Photos: 0
Default Best tube adhesive?
Just wondering what folks are using. When using medium CA to glue tubes, too often when I get a catch I notice that the blank doesn't seem to be adhered well to the tube. Is 2 part epoxy or Gorilla glue a better choice?
ramaroodle is offline   Reply With Quote Top
Old 05-10-2018, 02:24 PM   #2 (permalink)
mark james's Avatar
Photos: 481
Default
I have had great success with 2 part epoxy.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Old 05-10-2018, 02:30 PM   #3 (permalink)
Photos: 0
Default
This is a pretty broad question. The glue I use depends on the material being used. I would guess most glue would work for most applications but some glues would be way better than others. When I'm using wood I'll use CA because I want to keep the wood dry. Med CA is the thickness I use the most. I'll use Gorilla Glue for Acrylic and Deer Antler because I like the idea of the glue expanding to make sure there aren't any air pockets. I'll use the two part epoxy glue when I'm concerned about voids in between the wood and tube but want to keep everything dry.
Kenny Durrant is offline   Reply With Quote Top
Advertisement
Old 05-10-2018, 02:41 PM   #4 (permalink)
Photos: 0
Default
Hands down gorilla and or twp part epoxy.
Keep to make a good glue joint is at least 24 hours cure time. I have not had one failure sense going to 24 hours.
Had experienced failures with CA glue both thin and Med.
Charlie
Dieseldoc is online now   Reply With Quote Top
Old 05-10-2018, 02:42 PM   #5 (permalink)
Photos: 0
Default
Quote:
Two reasons the tube is not adhered adequately.
1. Drilled hole too big and 2. Not enough glue in the blank.
The tube should have little side to side movement.
You should use Play doh or something similar to plug the end of the tube, put some CA in the blank and on the tube and insert tube. This pushes CA all the way down the tube coating it.
wouldentu2? is offline   Reply With Quote Top
Old 05-10-2018, 03:05 PM   #6 (permalink)
monophoto's Avatar
Photos: 0
Default
Years ago, when my friend Max was asked at the Camera Club which camera was the best, his answer was always 'the plaid model'. His point was that it didn't matter which you got; what really mattered was how well you used it. Same principle applies here.
Seriously, everyone has an opinion here - what works for you doesn't work for me, and vice versa.
I generally dislike polyurethane glue because it seems to get all over everything and everyone within a couple of miles of where it's being used, but it seems to work well for me in this application.
By the way, are you abrading the tubes before applying adhesive? That seems to be a key factor in getting glue to adhere to tubes.
__________________
Louie
http://monophoto.deviantart.com
Instagram: @louie_powell_photo
monophoto is online now   Reply With Quote Top
Old 05-10-2018, 03:46 PM   #7 (permalink)
Photos: 4
Default
Try sanding the tube with 220grit and then wipe with alcohol to remove oils. Try not to touch the tube without a glove on, as oils from the fingers will get on the tube.
__________________
-John-
Terredax is offline   Reply With Quote Top
Old 05-10-2018, 03:46 PM   #8 (permalink)
Photos: 0
Default
+1 for 2 part epoxy.
RileyD is offline   Reply With Quote Top
Old 05-10-2018, 06:18 PM   #9 (permalink)
Photos: 0
Default
Thanks all.
Can't really do much about hole size. i.e. 7mm tube & drill bit.
Tubes abraded with 150 sand paper.
I use plumbers putty on the tube ends.
I'm leaning towards 2 part 5 min. epoxy and waiting overnight or at least a few hours. (the opposite of CA and turning in 10 mins)
Old 05-10-2018, 06:59 PM   #10 (permalink)
Warren White's Avatar
Photos: 0
Default My choice has evolved...
I used to use CA (medium), but I had a couple of cases of the tube getting stuck while I was putting it in. I think it might have been my fault, but it bothered me enough to make a change.
I now use 2 part epoxy all of the time. I went from 5 minute stuff to System III T88, which has (I think) a one hour work time. I bought this because I sometimes do a production run that needs more time. I am concerned that I bought it in too large of a bottle, because the Part B is getting a bit thick. It never has failed, though.
I, like others scuff the tubes with 150 grit sandpaper, and use plumbers putty to minimize the problems with clean up. I generally clean the ends after 1 day, and don't start turning until the following day.
Warren White is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
blank preparation
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
