8 ring Celtic knot
Brian G
Bloomington, MN
The way I approach it is to mill an approximately 125/128" square length of stock to an octagon by using a 45° chamfer bit in a router table. Then it's no different than making a 4 loop knot. Okay, maybe a little more anxiety is involved.
Example: 12th Bash Ballpoint Contest
I use a tablesaw with a 1/16" kerf circular saw blade. Make the knot material as thin as you can, but just a bit thicker than the kerf the blade makes. Then use a whisper thin spacer to increase the size of the kerf to fit the knot material thickness.
I've been meaning to write a tutorial, but I was interrupted by too many other projects around the house.
mark james
IAP Collection, Curator
Medina, Ohio
G'Day, Brian! Ya beat me to to post the info... Glad you were peeking!
As an aside; posting the specifics, will help; but not insure success... Practice, practice, practice
Oh, Have Fun!
(Still a brilliant pen that I envy!!! Cheers Mate!).
chartle
Pgh, PA
Making a thick pen with a steep angle also helps. Too thin or too shallow and its a Celtic lump. :)
Pierre---
France
You may cut an octagon, then cut without going through, stop a wee before having two pieces, this way the knot will stay in alignment.
