vwnw
Hi gang,
I know that when I turn pens I use mostly 2" or 2 3/8" discs and SIASOFT foam backed sanding abrasives. I can tear or cut the SIASOFT into whatever lengths I want. For the higher grits I go with my SIAAIR 3" discs with foam padding on the back and those go up to 4000 grit and then my micro mesh products after that!
However, I was wondering what size sanding abrasives other people use to sand their pens and other small projects? I am going to create a starter kit for Pen Turners that would be useful to Pen Turners supplying what you need most. Please let me know what you use so I can be effective in this process.
Vince
www.VincesWoodNWonders.com
Vince
