Squaring or Facing the blank
When and how do you "face" your pen blank?
  • Before turning the blank, I use a pen mill to face it.
    Votes: 92 67.2%
  • Before turning the blank, I sand the end to face it.
    Votes: 30 21.9%
  • Before turning the blank, I use a different method (please add in comments)
    Votes: 6 4.4%
  • During turning, I remove from mandrel and face with pen mill>
    Votes: 1 0.7%
  • During turning, I remove from mandrel and face withsanding method
    Votes: 1 0.7%
  • During turning, I remove from mandrel and face, using a different method (please describe, below)
    Votes: 1 0.7%
  • When blank is completely turned I face with a pen mill.
    Votes: 1 0.7%
  • When blank is completely turned I face using a sanding method
    Votes: 3 2.2%
  • When blank is completely turned I face some other way, please describe in commetnts
    Votes: 1 0.7%
  • Never face the blanks, get them square a different way (describe in comments)
    Votes: 0 0.0%
  • Never square the blank, I cut them "dead on" before I put the tubes in.
    Votes: 1 0.7%
  • Total voters
    137
  • Poll closed .
hunter-27
Passed Away Aug 14, 2013
Chadron, Ne, USA.
I primarily use the good old barrel trimmer in my dp. It may be out of style to do so but it works for me. I square it before turning and the give it a "touch up" before assembly if I think I have had any glue "issues" develop during finishing.
PenMan1
Eatonton, Georgia
I use either a belt/disc combo sander or trim "to the line" on the bandsaw and sand with a a RHarrell sanding disc. And sometimes, I use the dedicated drill chuck and face with a skew on the lathe.
ed4copies
Local Chapter Manager
Racine, WI, USA.
OK, the poll is up.
Please indicate an answer in the poll. I am planning to use this in one of the videos I hope to complete this weekend. So, your input will make the information more accurate.
THANKS!!!!!
Ed
ghostrider
Grand Rapids, Michigan
I voted the pen mill because I mostly use that with the drill press before turning, then after turning and finishing, I flip the mill around and put sand paper on it for a final touch up.
Of course there are exceptions. I just milled a piece of purpleheart that just didn't seem to be phased much by either the pen mill, or the disc sander. That's the only time I put it on the lathe and parted it down to close, and then used the pen mill for some, and 60 grit for the rest. For some reason, that piece just didn't mind tools or abrasives. The mill worked fine on a piece of stabilized Koa right after that, so it's sharp.:confused:
ctubbs
Murray, Kentucky
Ed, as usual, I go of the deep end. I use both the pen mill and the disk sander with a jig, primarily depending on the material being used. On acrylics and punky wood or even some wood that rather splinter than cut, I use the sanding process. On good wood that mills well, I go for the pen mill and drill press. so there, my answer is yes. Don't you just love it when some idiot as myself simply can not make up his feeble mind? by the way, I did vote 'sand'.
Charles
Wingdoctor
Columbus, OH
I use the pen mill before turning and if I am doing a CA finish I use sandpaper on a mandrel face to touch up the CA.
ed4copies
Racine, WI, USA.
Keep em coming, please!!
Nearly complete with "gluing the tubes", soon available with a couple clicks on YouTube.
Hope to complete Turning, Facing, buffing yet today (Unless I get really tired of looking at the video software).
This poll will help me determine how to present the "facing" vid. So, I thank you all for your input!!!
soligen
Sterling Heights, Michigan
Well, I would need to make multiple selections.
Kits: Pen mill before turning and mill after turning, or "Other Method" after. depending on mood or what mods I make.
Kitless: Always other method - usually while turning.
My Kit "other method" is to chuck the pen body in the collet chuck and square it using a tool. If the body has a taper, I use tape to fatten one side so it chucks true.
My kitless other method is to square before drilling, then again "just in case" after taping (apply chamfer to threads at same time. To square the other end, I often do this while it spins on my "kitless mandrel"
I like having many ways to do this so I can fit the technique to the need.
Linarestribe
Mount Vernon, WA
Charles
Exactly
Lenny
Searsport, Maine
I cut the blank square, turn to round, drill and glue in tubes...
Then trim with a barrel trimmer, followed by a quick sanding with a makeshift sanding mill.
I repeat the sanding just prior to assembly to remove any excess CA glue on the ends.
BKelley
Tucker, Georgia, 30084
I glue tube in blank, turn round using mandrel. After blank is round, I remove mandrel, install blank in three jaw chuck and face off down to tube. I'm using a Grizzly 7x12 metal lathe.
Ben
Pineville, Louisiana
I disc sand to the tube. After I have applied CA and sanded through 1/2 the colored pads I sand to the tube again. This gives a slight curve towards the hardware when I am done sanding with the rest of the colored pads.
76winger
Lebanon Indiana
I will generally use the barrel trimmer to square up the end and trim them down to the edge of the tubes prior to turning.
On a few blanks that I've learned are a little more brittle, I will us the disk sander to get the material down "almost" to the tube, then use sandpaper on the back of the barrel trimmer to finish squaring it up. again, this is prior to turning.
doddman70
Eugene, Oregon USA.
Well not really an option to vote for that describes what i do, I "rough" square the blank prior to turning, Basically get it real close, Then after turning I "Fine Tune" it using a sanding mill by hand.
MrWizard
Fresno,CA
squaring up the ends
I am still getting use to my pen mill, but for me square just before I mount it on the mantrel, and then after I finish a pen just to clean the ends before assembly. If their really out of square I will hit the sanding wheel briefly to help.
leehljp
Member Liaison
Tunica, Mississippi,
I use my small table saw with a sled and cut as close as possible and sand the rest with a sanding pen mill. I have a carbide blade cutter for the PM, but choose to use a sanding PM instead. No problems with this method.
ed4copies
Racine, WI, USA.
So far, we are running a large majority that do SOMETHING before turning. That is what I expected, but it's nice to confirm.
joefyffe
Passed Away Aug 19, 2018
Indianapolis (almost Zionsville) Indiana
I use a PSI 90 degree arbor. I have fabricated some sleeves for the various size tubes and at a 90 degree angle press the end of the squaring mandrel against the sanding disk and, by hand, rock the blank back and forth till it's square. Then I take a tube reamer and cut an angle on the inside of the tube to account for the slight curvature at the extension, say like on a sierra.
wiset1
Florida
I use a Universal Pen Blank Squaring Jig purchased from PSI when I first started turning. As soon as the CA is cured I use an xacto knife to clear the CA out of the brass tube then I put the rod and adapter through the blank and square it on the disk portion of my Disk/Belt sander combo. I'll seal the ends by pouring thin CA on a paper towel and twisting each end in it to ensure everything is sealed and good. Since I turn to bushings I find it work well for me to do it this way.
Dale Lynch
Hastings,NE
Square with a skew
Hi Ed,
Good poll,there's not a selection for the way I do it so I'll just tell you.I make friction fit mandrels out of dowling so I don't have to use bushings.Then I turn the barrels down 50-70%,square up the ends with the skew and then finish turning.If I nick the mandrel while squaring,no big deal it''s wood and I can make another.No need for a barrel trimmer or power sander,money saved.
best wishes, Dale
mdburn_em
Chesapeake, VA, USA
Need ability for multiple answers
1 or 2 depending on how closely I cut the blanks
1. I use a carbide winged pen mill if the blank is nearly exactly to size
2. I have a jig on my 8" circular sander that hogs the material off quickly if I've left a little too much material on the blank
3. I touch up at the end immediately after applying the CA. The CA is soft(er) and doesn't crack on me/lift from the end.
