My wife and I
My wife and I
  • It's hideous-toss it
    Votes: 0 0.0%
  • It adds character-make it
    Votes: 0 0.0%
  • clean it out with a dremel and add a crystal or something
    Votes: 0 0.0%
  • Other-?
    Votes: 0 0.0%
  • Total voters
dalemcginnis
Local Chapter Leader
Daphne, Al. USA
have a disagreement on what to do with this blank. It was going to be a sierra click pen.
dalemcginnis
Daphne, Al. USA
For those who want details. I turned one of my castings and when sanding discovered a large air pocket just below the surface. It broke open when I pressed on it. I had been mixing some of the color in the epoxy when gluing the tubes and it looked pretty good so I thought I would do the same for the hole. Only problem was I was out of epoxy so I thought I would just use CA. As you can see it didn't work. The spot is smooth and in my opinion looks better in the picture than in reality.
Gentleben
Odessa, Texas
You might trying using a parting tool and make a grove around and including the hole, then fill it with some type of inlay material. I have use fine glitter from a craft store as a decorative element. You put it in there a little at a time with a drop of thin CA glue and just keep going around until it is filled and proud of the pen surface. Then using a sharp tool turn until even. If you have small gaps or air bubbles, you might have to do it twice. Hope this helps.
stevers
Bullhead City, Az., USA.
Is it something so special it's worth keeping or just another blank? (hypothetical) I stopped worrying about that sort of thing. Unless it's irreplaceable, toss it and go on to the next one.
Texatdurango
Show Low, Arizona
I'm with Steve. I think the phrase "adds character" is way over used when it comes to salvaging junk blanks, just throw it in the trash and try again. Whose to say your spackle job won't fall out in a year then you would have an unhappy friend or customer.
dalemcginnis
Daphne, Al. USA
Originally posted by Firefyter-emt
Looks like a good way to fix it would be to turn off all the acrylic and inlay a new body over the tube. ;)
That was my first thought.:D My wife's the one who said keep it. Since I was just making the pen for myself I think I may try some type of inlay just for the practice and to see how it lasts over time.
Texatdurango
Show Low, Arizona
Originally posted by dalemcginnis
... My wife's the one who said keep it. Since I was just making the pen for myself I think I may try some type of inlay just for the practice and to see how it lasts over time.
Your wife decides what to do with your pens? Mine isn't even allowed in the shop!:D
dalemcginnis
Daphne, Al. USA
Since she keeps giving them away as fast as I make them, Yes:D Maybe one of these days she'll run out of people to give them to and I can actually make enough to try selling them.:D
sbell111
Franklin, TN
Heck, my wife is the one that does the good turning.
