chuck jaw recommendation
david44
Withernsea, East Yorkshire,UK
I have recently changed my lathe to a Jet. I purchased a NOVA G3 chuck and a set of JSPIN pin jaws which I find are excellent for drilling blanks. I may get a pair of dedicated blank drilling jaws later but the set up I have at the moment is highly recommended.
edstreet
No longer confused....
With the chuck you will need 2 additional things.
a faceplate ring: NOVA Faceplate Ring 2"
Cole jaws: NOVA Cole Jaw set
The faceplate ring is more precise than other faceplates that I have worked with also easier to use. Standard faceplates you have to remove the chuck, with the ring you just clamp it to the 2" jaws.
The Penguin
Houston, TX
you don't "need" a chuck ring or cole jaws.
bowls can very easily be started between centers - first cuts either make a tenon or a recess.
reversing can be done with a jam chuck
Dan Masshardt
Mechanicsburg, PA
you don't "need" a chuck ring or cole jaws. bowls can very easily be started between centers - first cuts either make a tenon or a recess. reversing can be done with a jam chuck
You don't even 'need' a chuck, although the overwhelming majority use them.
Check out Lyle Jamieson's videos for a long time bowl turner who only uses glue blocks and between centers turning.
