Celtic transmissions
Have you had a problem with the Celtic transmissions?
  • I've had no problem with them
    Votes: 6 40.0%
  • Only 1 transmission failure
    Votes: 6 40.0%
  • 2 transmission failures
    Votes: 2 13.3%
  • 3 transmission failures
    Votes: 1 6.7%
  • More than 4 transmission failures
    Votes: 0 0.0%
  • Total voters
    15
Monty
Group Buy Coordinator
Pearland, Texas, USA.
I've made 10 of PSI's new Celtic pens and have had 2 of those pens transmissions break upon assembling the pen. The tranny would just turn with out extending the tip and upon unscrewing the tranny from the body, it came apart in two pieces. In another current thread, someone else had this same problem.
My question, how many of you have had this problem with Celtic transmissions? Was I just unlucky with my 20% failure rate?
It is the same transmission they are using in most of their newer pens(Knights Armor, Victorian, fillibela etc.) They are all of questionable value as transmissions.
To bad they can't come up with a better one for the price they are charging for the kits.
____________________________________________________
Everyday I'm vertical is a great day
Whenever i hear something like this I hope it's a production defect that only affected a few pieces before being discovered (and hopefully corrected).
Did you contact PSI, Manny? Hopefully they will replace them at least.
PSI replaced mine with no problems.
Monty I ordered another 4 celtic pens from PSI and 2 of the tranmissions were defective. One came apart and the other feels rough when you turn it so far out of 8 celtic pens I have had to replace 4 tranmissions. They are great sellers seems to sell fast but with the tramissions problems I am not sure.
PSI was contacted and parts are in the mail.
The one I've made is sketchy at best. The point extends only a mere fraction from the nib and will not retract. I am fearful of forcing the pen to retract in case I should damage either the innards or the blank. The other three I purchased are languishing in the 'I'll-get-to-these-someday-after-PSI-fixes-the-transmissions pile'.
I have had two issues ... in one case the refill itself was catching in the tip end... had to ream out the tip with a drill bit. The second problem ... the refill was getting stuck up into the transmission too far so the tip wasn't protruding correctly ... pulled the cap off, reassembled and it was fine.
I have noticed on the Knights Armour that the tube can stand to be shorter to get the refill to protrude the depth I like. fwiw
My issue with the knights armor is the pen tip sticks out and when you open it is way to far out. 2 kits, measured both tubes and same issue.
