Introducing: MesquiteMan's Cactus Juice Stabilizing Resin - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > IAP Marketplace > Old Classifieds Archive
  Forgot Password
Old Classifieds Archive Threads from closed classifieds forums. For historical reference only.
Welcome to penturners.org!
Old 03-01-2011, 02:02 AM   #1 (permalink)
Head Moderator
MesquiteMan's Avatar
Photos: 18
Default Introducing: MesquiteMan's Cactus Juice Stabilizing Resin
(Click Logo to visit TurnTex Woodworks)
Are you interested in stabilizing your own blanks? Now available exclusively from TurnTex Woodworks: professional quality stabilizing and wood hardening resin in sizes to fit the hobbyist's needs!
MesquiteMan's Cactus Juice Stabilzing resin is a heat cured, water thin (approx 8 cps) stabilzing and wood hardening resin that is easy to use to obtain professional quality results in your home shop. Similar to Resinol 90C or Ultraseal, Cactus Juice is available in more size options to fit every budget.
Easy to Use:
To use MesquiteMan's Cactus Juice, simply place your blanks in a vacuum chamber and weight them down. Then add Cactus Juice to the container and pull a vacuum. Keep the vacuum going until the bubbles stop and slow down drastically and then release the vacuum. Allow the blanks to soak for 30 or more minutes and then remove them from the resin. Wrap the blanks in foil and place them in a toaster oven at 220 F for 45 minutes to an hour. Remove blanks form the oven, let cool, and get to turning!
Works GREAT on punky wood that is too soft to even drill.
I recently did a test with 8 punky spalted hackberry blanks. Each blank was weighed on a gram scale and the weight was recorded. Then the blanks all were stabilized with MesquiteMan's Cactus Juice and cured, then weighed again. The average blank had a 164% weight gain!
MesquiteMan's Cactus Juice Stabilizing Chamber
Also available is a stabilizing chamber that I custom designed to get the most out of your Cactus Juice. In order to stabilize 5 typical pen blanks in a pickle jar, you will need approximately 16 ounces of resin. With the Cactus Juice Stabilizing Chamber, you only need 10 ounces for the same number of blanks.
Made from welded acrylic, the clear sides allow you to see exactly what is going on in the chamber so you know when the vacuum cycle is complete.
This is the special edition version donated to the IAP Birthday Bash. Typical chamber does not have the laser engraving!
Like everything else I make or sell, your satisfaction is 100% guaranteed or I will give you your money back.
For more information or to place your order, please visit www.TurnTex.com and click on the Cactus Juice menu at the top right.
__________________
Curtis O. Seebeck
The original, affordable home stabilizing solution!
Now available exclusively from TurnTex...Alumilite Clear and White in 1 gallon kits (1/2 Gal A&B)
www.TurnTex.com
MesquiteMan is offline   Top
Old 03-01-2011, 02:11 AM   #2 (permalink)
gallianp's Avatar
Photos: 2
Default
Could not find "cactus juice" button to click?
__________________
Nothing Religious
Nothing Political
Just a place holder
gallianp is offline   Top
Old 03-01-2011, 02:42 AM   #3 (permalink)
Photos: 34
Default
I would expect that cactus juice is quite fermentable , but I didn`t see a glass to click either .
1080Wayne is offline   Top
Advertisement
Old 03-01-2011, 02:45 AM   #4 (permalink)
Head Moderator
Photos: 18
Default
The link it in the top menu on the right side along with my other blanks and stuff for sale. Here is the direct link to the page: http://www.turntex.com/index.php?opt...art&Itemid=121
__________________
Curtis O. Seebeck
www.TurnTex.com
Old 03-01-2011, 04:23 AM   #5 (permalink)
philb's Avatar
Photos: 119
Default
Have been waiting to see more info on this since I saw the Prize you donated in the Bash!!
Do you know if the Juice is able to be shipping internationally? Just as general enquiry for all the overseas folks.
PHIL
philb is offline   Top
Old 03-01-2011, 11:10 AM   #6 (permalink)
Head Moderator
Photos: 18
Default
Phil,
I can certainly ship UPS and am checking with USPS to see about shipping Priority Mail. MesquiteMan's Cactus Juice does not have any shipping restrictions so I do not believe it will be a problem shipping USPS but I need to make absolutely sure. I hope to get an answer today.
__________________
Curtis O. Seebeck
www.TurnTex.com
Old 03-01-2011, 11:32 AM   #7 (permalink)
THarvey's Avatar
Photos: 27
Default
Curtis,
Could the vacuum chamber be used for casting, as well?
I don't have a pressure pot. And, after seeing the pictures when one of your's exploded, I am a little antsy about using one.
Thanks.
__________________
Tim Harvey
2015 Birthday Bash: 2nd Place Antler, Horn & Bone Contest; 2nd Place Cartridge Contest; 1st Place New Contest Contest; & a Trivia Daily Prize
2014 Birthday Bash: Perpetual Passenger on the Losers Train
2013 Birthday Bash: 2nd Place Casting - Tube On contest (with my first ever cast)
THarvey is offline   Top
Old 03-01-2011, 02:03 PM   #8 (permalink)
Photos: 0
Default
Cool stuff sir.I will have to give stabilizing another go now that I have a real good pot to do it in.Victor
__________________
http://landfilllumber.com/
http://stores.ebay.com/landfilllumber
A rich person is not one who has the most but the one who needs the least.
\"Keep Tree-Cycling\"
LandfillLumber is offline   Top
Old 03-01-2011, 02:40 PM   #9 (permalink)
bitshird's Avatar
Photos: 61
Default
Cool set up Curtis, nice Vacuum chamber, how thick are the walls??
__________________
Ken Ferrell
Maker of the world famous Woodchuck Pen Pro
"Sharper-Faster- Easier
bitshird is offline   Top
Old 03-01-2011, 02:44 PM   #10 (permalink)
bitshird's Avatar
Photos: 61
Default
DUH Geez I should have gone to your site. Nice unit for sure,
__________________
Ken Ferrell
Related Content
Bookmarks
Tags
stabilizing
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
