Has anyone seen an attachment photo or video for attaching a DRO to the "X" axis? In the Library, or anywhere else?
O.K. I'll never mind! You had me wondering. I'm in the process, now, of making the bracket to attach to the cross slide. I'll send pics when I finish, if it works out.Okay, having thought about it some more.... it dawned on me that you might be using the correct axis designations rather than the commonly used ones. The correct ones being Z for the longitudinal, and X for the crosslide. So, if you're using the correct ones never mind what I just said:biggrin:
Mike
Joe,
Looks great. Anything special to look out for when doing the cross slide install, other than making sure its fits well?
Looks nice, clean and straightforward. No clearance issues under the chuck when the jaws are open? You also might want to think about some kind of cover. If oil or swarf get on the scale and in the reader, it's not going to work for long.
Mike
A little pen kit baggie works pretty well.Looks nice, clean and straightforward. No clearance issues under the chuck when the jaws are open? You also might want to think about some kind of cover. If oil or swarf get on the scale and in the reader, it's not going to work for long.
Mike
Mike: I think the only time I will have clearance issues is if and when I use the four jaw chuck. And THANKS for the heads up on the cover.
Mike
Mike
Chuck, I wasn't referring to the display. I meant a cover over the scale and reader. Where it's mounted there in the front of the crosslide, is where a lot of crap falls while working on the lathe.
Joe, the cover can be something as simple as aluminum roof flashing. It's not real high tech looking. But it's simple to bend, doesn't take up a lot of room and it's light so it can be held on with something as simple as a couple magnets. That way you don't have to drill and tap a bunch of holes to hold it on. The magnets also makes things simple when you find your first cover design runs into something or another and you have to re-do it:biggrin:
Mike
