tooling for threading - Page 3 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Metal Lathes
  Forgot Password
Welcome to penturners.org!
Reply
Old 05-07-2018, 03:32 PM   #21 (permalink)
magpens's Avatar
Photos: 76
Default
Danny,
Thanks very much for the clarification !
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 05-07-2018, 09:10 PM   #22 (permalink)
stuckinohio's Avatar
Photos: 3
Default
Quote:
Originally Posted by More4dan View Post
Quote:
Originally Posted by magpens View Post
Dan,
You referenced your thread with the above title which I read.
I must be missing something. . How does 0.253" relate to 5 mm ?
I calc that 5 mm would be 0.197"
I meant a Bock #5 nib and feed. Not 5mm. Sorry for the confusion. It is a strange thread size to use. It seem to be a poor mashup of 1/4" thread with a Metric 0.6mm pitch. Easy enough to re-create on a metal lathe but expensive to have made. I used these homemade taps for a handful of kitless pens, and they work quite well for aluminum, brass, and acrylics. They worked ok with stainless steel. I thread on the lathe with a tap guide in the tailstock to keep everything straight.
I've since joined in on the last group buy and purchased a set of plug taps for #5 & #6 JOWO and Bock feeds as well as some triple start tap and dies.
Making my own taps taught me how to thread on the lathe and got me into making kitless pens a year sooner than had I waited for the Group Buy. After threading on the lathe for a while I switched to taps and dies with the tailstock holders and guides. They are SOOOO much easier and quicker to use. The finish of the threads are also better and the mistakes are much fewer.
There is a great satisfaction in making your own tools too especially when starting out on a budget.
Danny
Danny,
I agree about the taps and dies being so simple. for some reason threading on the lathe seems like voo-doo magic to me. Basically because I haven't tried it yet I guess. I really wouldn't even fool with it but I want to improve my skills and there seems to be several things that require special taps. Namely the Parker Vacumatic pump and making my own pistons. From what I gather you need to use the lowest thread count per inch possible to reduce the amount of turns needed to extend and retract the piston. It is difficult to find taps and dies with a low TPI, at least for me searching the net and barely knowing what I am looking for... Another thing would be nib housings for manufacturers than Jowo and Bock.
I just wanna have the ability I guess!
__________________
Lewis
stuckinohio is offline   Reply With Quote Top
Old 05-07-2018, 09:46 PM   #23 (permalink)
More4dan's Avatar
Photos: 5
Default
Quote:
Originally Posted by stuckinohio View Post
Dan,
Danny
Danny,
Iíd be happy to talk you through threading on the lathe. Iím not an expert but Iíve learned through the internet and some practice.
What model lathe do you have?
Danny
More4dan is offline   Reply With Quote Top
Advertisement
Old 05-07-2018, 10:56 PM   #24 (permalink)
Photos: 3
Default
I have two metal lathes:
PM1127 and a vintage Logan Powermatic. I would be learning on the PM and using it primarily but the Logan will cut much lower TPI than the PM. Off the top of my head it goes down to 4 TPI
I'll forest Gump my way through the threading using the machinist book and internet/youtube until I get stuck then I'll reach out!
__________________
Lewis
Old 05-16-2018, 07:50 AM   #25 (permalink)
rherrell's Avatar
Photos: 114
Default
https://www.amazon.com/Micro-100-290.../dp/B00Q8M30KG
__________________
Rick Herrell
Pilot Mtn.,NC
"The pain of using a cheap tool lingers long after the joy of saving money has passed"
rherrell is offline   Reply With Quote Top
Old 05-16-2018, 08:00 AM   #26 (permalink)
Photos: 3
Default
Thank you Rick. I'll check it out.
__________________
Lewis
Old 05-16-2018, 10:39 AM   #27 (permalink)
Photos: 1
Default
Thanks Rick That company has a range of single point tools able to get into smaller including .100 diameter holes. Click on the blue Micro 100.
https://www.amazon.com/Micro-100/b/r...-bin=Micro+100
__________________
Pete
Proud to be the support staff and enabler of Marla Christensen.
Curly is offline   Reply With Quote Top
Old 09-30-2018, 09:58 AM   #28 (permalink)
lorbay's Avatar
Photos: 134
Default
Try Banggood. They have a ton of insert threading tools. And nearly always free shipping
Lin
__________________
"If you come to a fork in the road Take It."
Yogi Berra.
lorbay is offline   Reply With Quote Top
Old 09-30-2018, 10:47 AM   #29 (permalink)
Photos: 0
Default
Cutting external threads is relatively easy and only requires a regular tool bit ground for the type of thread you are cutting.
Cutting internal threads in small holes (where you can't actually see the threads or easily measure thread depth as you cut them) is much easier using a tap in a tap holder mounted in the tailstock with the piece mounted in the chuck (to be certain of concentrically to the bore).
If you're making a non standard thread size or thread profile, it's easy enough to just make a tap by external threading a piece of metal rod of appropriate OD (plain old mild steel works well on plastics, use hardening steel for harder materials).
If you insist on internal threading by single pointing, a small tool steel boring bar can be fairly easily reground to be a threading bit if you're reasonably good at tool grinding. (tool steel boring bars are available but not the most common so you may have to look around a bit. I've found carbide to be significantly harder to grind and resharpen than are tool steel boring bars)
frank123 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
