Thanks for all the help, I done went and did it!
Carl Pepka
Kenosha Wi USA
Now the waiting begins, off to Harbor freight to pick up a few other things.
Part # Product Price Qty Total
1212 Drill Chuck, 1/2" $10.95
1804 Arbor, Drill Chuck 2MT Short to 33JT $9.85
1930 Cut-Off Blade, P1N $7.95
2314 Die Holder $35.33
2418 Steady Rest, 0-1", Mini Lathe, Ball Bearing
3114 Quick Change Turning & Facing Tool Holder, 0XA 4 $ 55.80
3118 Quick Change Knurling & Turning Tool Holder, 0XA 1 $26.95
5200 HiTorque 7x16 Deluxe Mini Lathe 1 $ 1,500.95
rherrell
Pilot Mountain, NC
Don't be fooled by the "DRO" on the cross slide and compound handles, you still need to account for backlash. They work fine going one way but when you change direction you have to re-calibrate for backlash.
That's not meant to be a knock on the machine, just some advice. It's a great machine and LMS is a great company.
I used a Micro-Mark 7x14 when I started out and it served me well so you should have a blast with it!:biggrin::biggrin::biggrin:
Carl Pepka
Kenosha Wi USA
Thanks, Rick, duly noted.
More4dan
Katy, TX
You need one of these too.
3104 Tap Guide. It fits in the tail stock so you can tap straight.
https://littlemachineshop.com/products/product_view.php?ProductID=3104&category=
Danny
Carl Pepka
Kenosha Wi USA
I was going to call and ask about a tap holder today, looked at this and wsnt asure it was what I need, thanks bud.
Danny
More4dan
Katy, TX
Danny
Just make sure it fits your tail stock taper. The tip is spring loaded so it follows the tap as it threads into your work. Simple but effective.
Carl Pepka
Kenosha Wi USA
I gave them a call to make sure I got the right one. Nice CS for sure.
Sent from my iPad using Penturners.org mobile app[/QUOTE]
bmachin
Owensboro, KY
The tap guide is a must, but tap wrenches are just about as necessary. You CAN turn a tap with an open end or crescent wrench, but a tap wrench makes life a lot easier. They come in various sizes so you may want to wait until you purchase taps before you get the wrenches.
I'm partial to General brand collet type wrenches, but there are other choices.
Bill
