I'm still new to all this so excuse my ignorance on what we call what on a lathe but in my case I just rotate the "top slide" which sits atop the "cross slide". If I want a 15 degree taper I just set the topslide on 7.5 degrees and it works fine.
Haynie, I don't know what constitutes a PITA but I can be turning a rod to size, stop, loosen 4 nuts, rotate the top slide to whatever degree I want, retighten then I am cutting a taper, it's that quick and easy.
Edit: I just watched the link provided above showing Tubalcain turning a taper using the "cross slide" offset and it's the same video I watched last year so I guess I'm getting too technical when I say it's the "top slide" method.
