There are so many variables that a speed chart will just get you in the ballpark. Type of metal, diameter of the workpiece and depth of cut are the three to consider most. I turn alot of W1 drill rod and if I take a .005" cut on a .500" piece I use about 1000 to 1200rpm, a .015" cut on the same piece and I turn it down to about 500 or 600rpm.
Generally, the bigger the piece, the slower you go.
