okiebugg
Determining the center line of a rod in my mini is a problem when it comes to 'centering' the cutting tool. What or how do you first, find the center line adequately, and second, shim the bit to match.
What do YOU use to shim ?
I feel that I do a fair job at centering, but you wouldn't believe the happenstance way I achieve this. I still see the occasional 'jump' when cutting from being below center.
You would probably be astonished that I use some of the shimming materials that I use just to achieve the end result..
