Artisan iron designs
I hate mondays. My 13" south bend started to make grinding noises last week so I shut down my job (which was turning 25 damascus pens) and took off the head stock spindle today. I found a destroyed thrust bearing which is easy enough to fix. The hard part was when I found a groove ground into the top and bottem journels. now I have to do a complete tear down just to take the head stock off. that means remove the saddle, so I can take off the lead screw, so I can take off the quick change gear box, which will give me access to the bed mounts, and so on. to make matters worse i need to give my blanks to a fellow machine shop just to finish the order...it just doesn't pay to get out of bed some times.
