Multi start threading
titan2
North Highlands, Ca, USA.
Start here
http://www.penturners.org/forum/showthread.php?t=53114
Edited in. For future reference you might want to bookmark this link. It is a thread on triple threading on the lathe by one of the best ..."SkipRat"
I've just finished making a PowerPoint Presentation using SkipRat's posts and it much easier to following that opening each of his 25 pictures. Not able to upload it yet, but if you'd like a copy I can send it to you via e-mail.
Barney
Timebandit
Austin,TX
Start here
Barney
I'l take one. Thanks
titan2
Start here
Barney
Justin,
Send me a PM with your e-mail address and I'll send it on.....
Barney
el_d
Lockhart, Tx, USA.
Start here
Barney
Me too if possible???
titan2
SkipRat's 3 Start Threading PowerPoint Presentation
OK, everyone.....I've been able to add the PowerPoint Presentation to this post.
Check it out and see if it works for you.....let me know how you like it.
Barney
PS. Replaced the PowerPoint Presentation with another one to make slide #20 clearer. Hope it helps!
  • Skiprat's 3 Start Threading.ppt
TomW
Allen, Texas
I must be missing something... How does the procedure insure that thread 2 and thread 3 start 60 degrees from thread one??? (evenly spaced around the diameter)??? Needs more info around slide 20...unless I'm fouled up... which is very possible...
Tom
Russianwolf
Martinsburg, WV, USA.
Tom
Slide 19 shows the thread is a 3mm
Slide 20 say to advance by 1mm for the second thread. And by another mm for the third thread. That will make the threads 1mm apart and starting 60 degrees from each other.
If you get to slide 19 and yours is showing the thread as 2.4mm then you'd need to advance by .8mm to get the second thread aligned. Always 1/3rd of what the thread distance is in slide 19.
Haynie
Page Arizona
Stupid question time:
Is this just for practice making this snazzy rod or does it go on a pen somewhere. Prescription Anti-inflamitory/screw-my-thinking-up pills are making it real hard to process.
How do you know where to start the second thread?
titan2
Barney
Replaced the PowerPoint Presentation and hopefully slide #20 is a little clearer now. Let me know if it's clearer.
Barney
