mini lathe 7x12
graham murfin
wark forest,northumberland,uk
Hi
I have been doing a bit taper turning on a colchester bantham a favourite of mine as it has a powered crosslide but still have to turn handles for tapers.
I have a recent mini lathe with variable speed, when i went to do some tapers the machine has the angles marked but it doesnt turn to them, they are just for show and the topslide is fixed 90 degrees - what a cheat :curse:
graham
Dalecamino
Local Chapter Leader
Indianapolis, In.
Graham, welcome to the forum. I really enjoy making my nibs with the "Etch-a-Scetch" method. It's fun cranking both wheels at the same time while, trying to get it right. However, not everyone likes the shape of them.:crying:
graham murfin
Hi Chuck
i was great at etch a sketch....making houses with wholopping chimneys, i tend to make form tools and move them about and blend them in.
Ive seen an attachement u take out the crosslide leadscrew and its spring loaded onto a form with a rear roller, a bit like the old copying capstans.
graham
bluwolf
SW Florida
Hi
graham
I read this awhile back but it didn't set in (I can be rather slow sometimes). I don't know if you've checked but the mini's angle adjustment is under the topslide as opposed to on the sides of it. You have to crank the topslide back until you expose two bolts. Crack those loose, adjust your angle and snug them back up.
Mike
bluwolf
SW Florida
graham
Mike
Then remove the handle from the top slide and put on an extra nut. Use a variable speed electric drill with a socket to provide a power top slide.
Chuckie
Yup, that's the way to do it. Much better surface finish. I've also put one of those cheap flexible extensions in between the socket and the topslide screw. It allows you to hold the drill at a more comfortable angle and doesn't transfer any of yours or the drill's movement into the crosslide.
Mike
graham murfin
Hi
graham
Mike
Hi Mike
and thanks a lot you were right about the angled slide there must be a circular tee slot underneath, I,m never too old to learn.
graham
graham murfin
Hi Chuck
after looking at all the photos, and fancy turning, my pens are rather ordinary, i try to make a good job and use new ideas i think of, but they are not exotic and i suppose boring to fellas who make pens everyday, I am starting to use copper and brass with acrylics but wait a few weeks.:wink:
graham
