metal lathe motor wiring.
darrin1200
Lyn, Ontario, Canada
I have a Standard Modern 10" Utilathe. It currently has a 1hp/115v/1725rpm motor (not original), with a normal single pole light swith for an on/off.
Originaly, these lathes came with a Master power switch, a fwd/rev swith and an on/off. I would like to set it up again similarly.
First question. Can my motor be reversed? From what I can see on the motor lable, all I have to do is reverse the wires. True?
Second question.*What type of switches can I use to acomplish this? While i dont want to scrimp on safety, I also have to keep my budget frugal.
For the master switch, not starting the motor, I figure a regular light switch should be sufficient. The reason for a master switch, is to power a couple of lights that I want to mount, as well as a future coolant pump.
Should I use a magnetic switch for the motor on/off?
As for the reverse, I have no idea what sort of special switch is needed.
I have attached a photo of the motor info.
​​​​​​​Thanks for any help.
darrin1200
Thanks guys. That clears it up enough to get me going.
I am going to pick up a drum switch for reversing, and a Mag switch for power. I like the idea of the switch disconecting in a power outage.
