duke851
I made the attached chart to try and help get my mind around thinking in metric and using an inch lathe.
My lathe is a Prazi MD300 and has the following the hand wheels as follows
Cross slide
Increments - one revolution = 50 x .001" = .050"
Marked 0 - 9 every .005" and also marked every .001"
Lead screw, Tailstock and Compound
Increments - one revolution = 25 x .001" = .025"
Marked 0 - 4 every .005" and also marked every .001"
The attached PDF converts everything into mm and in the final column gives the total stock removed.
I checked it with a dial indicator on my lathe and it showed that in is very close with the actual carriage movement being fractionally less than the chart (on the safe side). For one complete revolution of the Cross slide the chart shows 1.270mm movement and the dial indicator read 1.265mm.
An actual cut of some scrap showed cuts to be within +/- .04mm of the chart.
I have to add though that I am not a machinist and would welcome any feedback. (like if I have this totally wrong)
Colin
Cross slide
Colin
