Compound cross slide
Millersburg, OR
A friend of mine is wondering if it is possible to mount a cross slide on a wood lathe to cut a taper on a 1/4 17-4 stainless rod. It doesn't need to be precise just a point. Presently he is using a grinder and a drill and takes about 3 min to do it. Also would a Beal collet chuck hold it tight enough? any ideas?
Russianwolf
Martinsburg, WV, USA.
yes and no......
that vague enough for ya.:wink:
I have a cross slide that I bought for exactly this purpose in my shop. But the critter is over 7 inches tall before putting the tool holder on it. I have a 16 inch lathe, so I'm working on mounting it but it isn't easy. I have my plan but have had a chance to execute it.
thetalbott4
Roy, Utah, USA.
Havent done it, but i know if he can find a way to mount it and the hieght works out to line up with the centerline of the lathe shaft, the lathe should be able to handle it. If its not a critical taper, 3 minutes isnt bad for a drill and grinder. Might not gain much time. Better taper though.
palmermethod
Arvada Colorado, USA
Went through the exact same thought process and decided it was an upohill battle to convert a wood lathe into a metal lathe. That is why I bought a Sherline.
And cutting metal on a wood lathe is hard. Collets for metalwork usually have a drawbar feature where the material can be tightly clamped. A wood collet won't work.
:) PM
Gin N' Tonic
Waterbury Ct. USA
Yes it is possible and I have done it.
BUT............
You are going to put a whole lot of stress on the bearings of the lathe and wear them out much faster (DAMHIKT) You didn't mention what state the 17-4 would be in?? Condition A (Softest) or is it hardened? H900, H1150 Etc. I won't cut anything harder than aluminum on my wood lathes because in my opinion it's just not worth the hassle.
