manojd
I had a small disaster today while working on metal inserts. The gears froze while using auto-feed. Thankfully the lathe turns off automatically, otherwise it would be a bigger disaster. Upon inspection, I found out that the bush which holds gear B and C had been jammed. As a result the 80T gear got damaged along with the keyway.
This is what it looks rightnow:
Is there any way to repair this gear? I had thought about relocating the keyway, however enough material has been sheared that simply relocating will not help.
Thanks.
Thanks.
